Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 11-30-2006, 01:20 PM
shanicmer shanicmer is offline
NEEDING Temp Gage HELP
Hey I have a 96 Max GXE and I am having a tough time finding out why my heat and temp gage only goes up to normal when I am sitting still. When I go down the road my temp gage goes down to about nothing and the heat in my car drops as well. I tried putting something behind the grill but that didn't seem to help. Any ideas? Also my heater dosen't put out as hot of air as it should. Any ideas on that? One more thing...I need to replace the rear struts and there seems to be like a lock nut in the way of the bottom bult. Is that normal and if so is there a way to get it off without taking the whole brake and rotor off?
Old 12-01-2006, 10:02 PM
chmsl's Avatar
chmsl chmsl is offline
Re: NEEDING Temp Gage HELP
Have you checked the condition of your cooling system? Make sure
you are topped off and there are no leaks. You may have air in the system
and this would cause the low to no heat symptom.
Old 12-03-2006, 07:09 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Cooling problem: Thermostat is stuck open or has been removed.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
