Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-30-2006, 04:41 AM
scheere11s scheere11s is offline
Exclamation Need help starting!!!!!
I have a jeep wrangler x. It wont start. it has been cold i started my jeep just fine went to work and when i went to get in my jeep like 10 min later it would not start i left nothing on i went bought a new battery the old batter was tested as "BAD" and now when i go to start the jeep it clicks and then its like a whineing noice that stays on until i stop truning the key..... Could this be a fuse problem just before i started it i believe the check gages light came on an it had no oil pressure but drove fine then the oil pressure kicked in in abot 2 min. ALSO about a week before that all my gages when out and it said no buss i checked all fuses and there fine? ???? jeep has at lest 8 gallons of gas in it as well. please help
Old 12-29-2006, 10:56 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Re: Need help starting!!!!!
Did you find the problem???
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 01-02-2007, 11:53 PM
cj hupp cj hupp is offline
not sure if this will help.I have a 95 with a 4 banger,and had similar problems.My yj would also make a clicking sound and some other strange noises,then it would start(sometimes).I found the clicking noise coming from the relays under the hood next to the battery.The only time my jeep would start is when the check engine light would come on.When it would not start the light wouldnt come on at all.Since that is how you check the codes on these jeeps (by the check engine light).I figured it must be the computer.I replaced the computer with one I bought off ebayand it worked.Its been running fine ever since.GOOD LUCK 0IIIIII0.
Old 01-03-2007, 09:56 AM
IT MAY BE A RELAY GOING BAD.
