Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-29-2006, 07:58 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
DP rubbing on oil pan
I took my gsx to the shop to change all the fluids today and i noticed that the flexible part of the downpipe is up against the oil pan. Im sure this isnt good. It doesn't look like its rubbing but im sure everytime i shift it rubbs a little bit and i dont want to get a hole in the pan. On top of that im sure that excess heat is warming up the oil a little more than it should be. I had planned on getting some exhaust wrap tomorrow and wrapping that part of the DP. Does this sound like a good idea to keep the metal on metal rubbing and the heat transfer to the oil to a minimum? Or should i look into doing something else. Taking it to the exhaust shop to get it custom fit is my last option but id like to see if there would be an easier cheaper fix before i take that route. Thanks
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-29-2006, 08:10 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: DP rubbing on oil pan
I would get that hose away from the pan or try to secure it to something because excessive rubbing isnt a good thing.My neon had a similiar problem with the tranny line and it rubbed a hole in it and next thing i know the tranny went out and my trunk was covered with tranny fluid.It now how a blown engine trying to keep up with my buddies Eclipse but thats a different story.
Old 11-30-2006, 08:25 AM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
I had the same problem with my megan downpipe. It bolted on correctly but right onto my oil pan. Rather than take any chances i took it back off a took it to a local muffler shup where they cut and welded in a piece at the neck where it bolts onto the o2. This gave it the extra 2 inches of clearance and only cost $20. I dont have clearance issues with the downpipe to the ground either. Hope this helps.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 11-30-2006, 02:02 PM
Well i took the car to a couple exhaust places today and they either said there was nothing they could do or that they dont work on aftermarket exhausts. Sounded pretty strange to me since im sure most all of the cars they work on they r putting a aftermarket exhaust or making modifications to one. Or maybe they just dont like mitsubishis. Thats why id rather do things myself. So do u think itd be ok to put that heat wrap on it to cut down on the friction between the dp and oil pan. Or maybe i should just take off the DP and bring that to the muffler shop instead of it being installed on my car.
94 Talon 1.8L-SOLD
Old 11-30-2006, 09:38 PM
From what Ive seen heat wrap works magic so yes its surely something that you could try.I replaced my hoses with high preassured ones also to reduce the chance of them busting under a load.Good luck and I hope that I have helped in some way.
