Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-29-2006, 08:19 PM
stlneese stlneese is offline
Exclamation 2000 Malibu LS, LOUD grinding sound from engine
Two days ago my car made a loud, obnoxius grinding sound when turning, then the noise stopped. I started it up today and it now makes the loud, obnoxious grinding sound nonstop, in park, drive etc, making it undriveable to the service shop. I cannot at all pinpoint the location of this sound in my engine. Any advice? HELP!!
Old 11-29-2006, 09:00 PM
bcopeland bcopeland is offline
Re: 2000 Malibu LS, LOUD grinding sound from engine
1) Starter sticking?
2) Valves loose (loose rockers)
You need to pinpoint the general location of the sound and reply.
Old 11-29-2006, 10:41 PM
I'll try to find the origin and reply. Thanks for the help!
Old 11-29-2006, 11:06 PM
I started her up again and this time no noise. It did make a quick grinding sound as if I turned the key when it was already started. It has typically only made this noise long after running for awhile and gone away quickly, so could it still be a starter problem?
Old 11-30-2006, 01:47 AM
twistedtech twistedtech is offline
Tensioner bearing,Alt bearing,PSPump bearing,A/C clutch and/or bearing.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 11-30-2006, 02:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with twisted. Check the A/C compressor clutch for little bits of metal shavings. If you see them, the AC pulley bearing has failed and you need a new compressor or compressor clutch and pulley. Very common issue on these cars. If the noise quiets down or goes away when the A/C is on, and gets louder when you turn the A/C off, it's definitely the compressor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
