Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 11-29-2006, 07:10 PM
christopher777 christopher777 is offline
1998 CR-V cruise control doesn't work
Greetings. I just bought a '98 CR-V/5 speed, and my cruise control doesn't work. I tested it on my 10 hour treck to get it home, and I could occasionally hear a slight clicking noise when I engaged the master switch and then hit the "set" button on the steering wheel. However the green light never illuminates on the instrument panel. The fuse in the indoor panel seems to be fine; I swapped it with another 7.5A fuse this afternoon.
Any pointers on where I can start looking?
Thanks.
C
Old 11-29-2006, 09:13 PM
paulbert paulbert is offline
Re: 1998 CR-V cruise control doesn't work
i know that on my '99 crv, the clutch pedal gets stuck sometimes which stops the cruise control from working. u could try that
Old 12-20-2006, 11:57 PM
tareq75 tareq75 is offline
is ur gear automatic or manual?
you might need to reset the computer and check the light itself in the instrument panel before going deeper into cruise control stuff...
hope 2 hear from u pal..
Good luck
Old 12-31-2006, 03:15 PM
Hi,
thanks for your response. My CR-V is a manual transmission. I suspect that I've recently reset my computer; I unplugged the battery for 10 or 15 minutes last week when I replaced my spark plug wires (other issue...and plugs, distro cap & rotor...still have a check engine light that was tested, and came back relating to the spark plugs).
Correct me if I'm wrong on that. I tried the button again last night on the highway; no luck. The switch lights up on the panel, but the Set button still does nothing. I occasionally hear a slight click noise, but when I lift my foot from the accelerator, it slows down.
I appreciate any ideas you have with respect to that!
Merci,
Christopher
Old 01-01-2007, 04:25 AM
i guess this is a sign from HONDA... TAKE ME TO DEALER!!
you need to check ur engine for error codes.. its better to be safe than sorry i guess...
Old 01-01-2007, 09:54 AM
LSC9901 LSC9901 is offline
May sound stupid but are you sure all your lines are properly connected ??? Just a thought before you run to the dealer and pay them a fortune to do the same thing. I also found that any pressure at all on the clutch disables the cruise control.
