| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Installed FMIC GOT PROBLEM
I finished mounting the front mount intercooler and running the piping and took it for a test drive with the bumper still off and when it gets to high RPM's and near full boost the car sputters pretty bad. The other thing that is wrong is that when im just normal driving feather footing it, there is a whistle immediately after letting off of the gas every time. It is really high pitched like the bell when you walk into subway. Is there most likely a boost leak somewhere or is it something else?? any suggestions are appreciated....
![]() ![]() SOLD '97 GSX EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels '05 blacked out f150 FX4 |
Re: Installed FMIC GOT PROBLEM
sounds like something is loose or leaking i would go back over every clamp and connection
1992 eagle talon tsi awd xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit |
my guess of the sputter is maybe a electronic tuning issue? i dont know thats my guess and the whistle noise can be the BOV...check it when its at idle. rev it a couple times to see where that high pitch whistle noise is coming from.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
nothing can EVER go right the first time thats the law... i made gaskets for the bov and the throttle body out of rubber gasket maker but im pretty sure i had it on there perfect adn tight as hell....
Check the piping to be sure there are no leaks.
What fuel mods do you have? And the noise when you let off, if I had to guess would be your bov ![]() If it's making a noise when you are letting off the gas, sounds like it's working right.
1991 GSX 2.3 Stroker |
Now, that gasket maker won't hold for shit on the throttle body... The previous owner did the same thing to mine, and I had some huge boost leaks outta my TB... I've replaced them and the car should run much better... ^I'm suggesting replacing that... also, check all the other connections, that's most likely where it'll lie...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
When i put my intake on it made a whistling noise when making full boost but it was a boost leak on one of the rubber couplers. Not sure why it would make the noise when u let of the gas maybe a leak on the bov. When i did my boost leak test i found one on the throttle body between my new UICP and TB, and also on my BOV with a new gasket. THrew some RTV on both sides of each gaskets and no boost leaks.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
I vote boost leak... Give it a leak test and find out where its coming from.
-Brian
its not a bov sound when i let off its a longer faint high pitch whistle..
And what do you suggest to make the gasket with on the throttle body
(TB gasket is at the bottom of the page) http://www.slowboyracing.com/shop.ph...be74d9532fb806
Boost leak!
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
shouldnt making your own gaskets work just fine instead of buying them for 10 bucks or more? How thick does the throttle body gasket have to be?
My experience was otherwise... maybe it'll work for some... but from what is happening to your car, I would think otherwise...
Check for other leaks first, if you don't find any... spend $10...
well i decided to rip all the piping apart and i got the gasket maker goop from NAPA and make the throttle body gasket and the bov gasket. I dropped one of the four corner nuts on the throttle body down and it got stuck somehwere inside the engine bay so i need to get another one of those.... Does anyone have any opinions on that gasket making goop?
Also is connecting pipes with couplers and clamping like a hard thing to do or once its clamped down tight is it good?
