Old 11-29-2006, 03:53 PM
trojan84 trojan84 is offline
93 Accord brake system problem
Car has 150K miles. Was having issues with brake pedal gradually creeping to floor so I replaced master cylinder with aftermarket one. Bled brake lines on each wheel but problem didn't go away. I thought maybe fluid was bad, so I continued bleeding until 2 quarts of new fluid in system. Old fluid was dark/carmel colored. This worked for about 2 weeks. Now the brake pedal goes fairly quickly to the floor and now not safe to drive. When engine is off and brake pedal depressed, can still push it to the floor. Is my new master cylinder faulty?
Old 11-30-2006, 06:51 AM
hahakenny's Avatar
hahakenny hahakenny is offline
Send a message via AIM to hahakenny
Re: 93 Accord brake system problem
I have a 95 Accord that had a similar problem. For a while, my pedal would have to be pressed down all the way in order to stop. I had my master cylinder replaced but it kept happening. The shop didn't know why. I then took it over to Meineke (who specialized in brakes) and it turned out that one of my calipers was missing a pin and was not working. After they replaced the pin, my pedals were solid. I had them clean the caliper sliding bolts as well. I have no problems now. Hope this helps.
My 95 Accord EX
Old 12-01-2006, 02:21 PM
somick's Avatar
somick somick is offline
Did you bench bleed you master cyllinder before installing it?
I have heard that old hoses may just swell. Check it out as well.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 12-04-2006, 08:18 AM
No, I didn't bench bleed the cylinder. How do I do that now, with it installed? Explain "bench bleed" please. Thanks.
Old 12-05-2006, 03:48 PM
somick's Avatar
I have never done it on Accords... I think Honda's master cyllinder is a bit different. So I dis a search...
Read these threads:
http://www.automotiveforums.com/vbulletin/showthread.php?t=635467&highlight=bench
http://www.automotiveforums.com/vbulletin/showthread.php?t=457379&highlight=bench
Old 01-10-2007, 04:40 PM
Took old cylinder off, took apart and cleaned, reassembled, bench bled it......still didn't work. Bought new one and bench bled it this time and everything works fine. Thanks for the help everyone.
Old 01-10-2007, 04:58 PM
somick's Avatar
Thanks for update! I am glad it works!!!
In your first post you said you used aftermarket MC.
What did you use now?
Sam
Old 01-11-2007, 08:03 AM
Assume it was an aftermarket. Bought from Autozone as it was 1/4 of cost of OEM. First one bought off internet
Old 01-11-2007, 12:50 PM
mpumas mpumas is offline
Master cylinders are not rocket science type devices. The reason a master creeps to the floor is that the cylinder is scored or the rubber cups are worn out. If a rebuilt one doesn't work means it wasn't rebuilt properly. I would never buy one off the internet unless I rebuilt it myself before installation.
Old 01-11-2007, 02:11 PM
Good for you. These were brand new master cylinders, not rebuilt ones.
