Old 11-29-2006, 03:09 PM
greenmachine1 greenmachine1 is offline
Antenna Pole: How to remove antenna ring nut on outside base
I need to replace the antenna mast on 94 GT3000. The antenna motor removal instructions indicates the 1st step as removing the ring nut. What type of tool is used?
Does anyone know if I need to open up the trunk compartment to access the motor antenna (thus removing all sorts of trim), if all I am doing is replacing the mast & attached (plastic toothed) rack cable? Sounds like it can be all done from the outside of the car.
Thanks in advance for your help.
Mark
Old 11-29-2006, 06:01 PM
miami3000gt miami3000gt is offline
Re: Antenna Pole: How to remove antenna ring nut on outside base
i need to know why my antenna never goes up is it supposed to stay down there?
1995 mitsubishi 3000gt Base Model - working on her
Old 11-29-2006, 07:58 PM
Igovert500's Avatar
blue + red light magnet
http://www.vr4stealth.com/antenna_mast_replacement.htm
No it's not supposed to stay down, maybe it's stuck, maybe you need a new motor. Whatever hte reason, if you want to discuss it, please start a new thread, rather than hijacking somebody elses.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
