Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-29-2006, 11:29 AM
satskar satskar is offline
Unhappy 97 Dohc starting trouble
I have a 97 Sc2 Dohc with about 95k miles on it. Recently it has had trouble starting after sitting for more than an hour. It has charge ( cranks easly ) also just replaced plugs/wires, and the plugs looked good. When it does start (5-10 second hesitation) i get a gas smell even if i didnt pump the gas. Even at idle if i tap the gas, the rpms seem to go down before they actully go up. I checked the vacuum lines on the fuel pressure regulator, and it seems ok.
Update : Just went to Autozone to have them scan the car, came back with a 341 code (cam sensor) Is this maybe the cause of my problems.
I'm At a loss, any help would greatly be appreicated.
Thanks
Old 12-02-2006, 02:30 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: 97 Dohc starting trouble
97s had really bad fuel pumps that year for some reason,(mine didn't) and from your description, that's my guess.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 12-03-2006, 07:32 AM
whoareyou4 whoareyou4 is offline
I just had that same problem yesterday and I fixed it.
Saturns don't have a Cam Position Sensor, except my code was P0340. My problem was corrosion on one of the coil pack towers which caused corosion inside the ignition wire boot.
Here are the instructions I used to solved the problem:
P0340/P0341 Troubleshooting S-Series
Most of this came from TSB 98-T-49A, and a few of my tips thrown in.
Both P0340 and P0341 both relate to the Camshaft Position Sensor(I will just call it Cam sensor from now on), the only problem is that the S-Series engines don't have a Cam sensor, not a typical one at least. instead, the DIS module watches when the #4 spark plug fires on the compression cycle and fakes a Cam sensor signal from it. the tricky part is that on a DIS waste spark system, spark plugs fire with their mated cylinders(1/4 and 2/3 in 4 cylinder engines) every time the cylinder is at TDC, regardless of weather the cylinder is on exhaust or compression. However, it takes far more voltage to fire a spark plug on the compression stroke then on the exhaust stroke, due to the compressed air(more air molacules, more air the spark needs to jump, more resistance to spark). The increased voltage needed on the compression stroke is detected by the "#4 sensing circuit" inside the DIS module for the Cam sensor signal. if the resistance of the secondary system is not in the proper range or something else is affecting the voltage draw, the "#4 sensing circuit" will be unable to work properly.
In short, anything worng with the ignition system, bad Cam sensor signal.
Next for the diagnositic, i'm converting this from a graphic map to a text format, so bear with me...
Step 1: remove secondary wires from spark plugs, keep the wires on the coil. measure resistance from #1 wire to #4 wire and then #2 wire to #3 wire. resistance should be 11k ohms to 45k ohms(YIKES thats a wide range)
If resistance is in specs, go to step 2, if not in specs, go to step 3
Step 2: remove secondary wires from the coil packs. check for corrosion on the towers and wires.
If there is corrosion, go to step 4
If not, go to step 5
Step 3: remove secondary wires from the coil packs. check for corrosion on the towers and wires.
If not, go to step 6
Step 4: Replace or clean coils and/or wires as nessaciry. Retest to confirm.
Step 5: Remove spark plugs. Check for carbon or abnormal wear and proper gap(0.040 in)
If plugs check out good, go to step 8.
if the plugs are bad, replace as needed and retest to confirm.
Step 6: Measure resistance of individual secondary wires. specs are 1.5k ohms to 15k ohms ( thats what this chart says, but my knowage says 8k ohms is normal, greater then 12k ohms should be replaced)
If wires are in spec, go to step 7
If wires are bad, replace as needed and retest to confirm
Step 7: Measure resistance from tower to tower on the coil packs (hold tight for good reading). Spec is 8K to 15K.
If coils are in spec, go back up to step 5
If coils are bad, replace as needed and retest to confirm
Step 890% of the time i bet the problem is solved by now) Start engine. Perform underhood visual inspection of the ignition system, check for arcing(best done in a dark area, if you are inside a garage, besure the exhaust is vented). Wet DIS module, coils, and secondary wires with salt water to provide optional ground path.(arcing from the wire boot to the valve cover is possible, but would be hidden)
If arcing is present, replace wires or coils as needed and retest to confirm.
If not, go to step 9.
Step 9: Turn ignition off, backprobe J3D03 (Circuit 633, brn/wht wire) at PCM with voltmeter. connect other lead to ground. Turn ignition on, engine off. Measure voltage.
less then 4.5 volts, go to step 10
4.5-5.5 volts, go to step 12
more then 5.5 volts, go to step 11
Step 10. Check connections in circult 633, repair short to ground, retest to confirm
Step 11. Repair short to voltage in circuit 633, retest to confirm.
Step 12. Start engine, at idle observe voltmeter
less then 2.0 volts, replace DIS module, retest to confirm
2.0 - 4.0 volts, problem intermittent
4.0 - 5.5 volts, go to step 13
more then 5.5 volts, go back up to step 11
Step 13. Turn ignition off, backprobe circuit 633 at DIS module with voltmeter, other lead to ground. check voltage.
4.0 volts or less, repair open/high resistance in circuit 633, retest to confirm.
greater then 4.0 volts, go to step 14
Step 14: Inspect terminal on DIS module for looseness or poor connection.
If terminal is bad, repair it
If terminal is good, replace the DIS module.
thats all of the diagnoistic chart, anybody who has done this in the past feel free to throw in your tips/opinons. I would like to add three things:
1. Check the grounding bolt on the DIS module for corrosion.
2. besure the secondary wires are fully seated, you should feel/hear a click
3. use dielectric grease on the coil towers
