Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-29-2006, 09:49 AM
ariel's Avatar
ariel ariel is offline
swap 22re for a 22r
I have a 1985 toy pu and just gota 1990 pu, the 85 has the 22r and the 90 has the 22re. Can I swap engines and still use the fuel injection system and exhaust manifold that is in the 1990 22re on the 22r.
thanks AL
Old 11-29-2006, 12:05 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: swap 22re for a 22r
If you're wanting to put the '85 22R in the '90 and put the EFI stuff from the RE onto the R, the answer is yes.
But you'll also have to drill and tap the 22R block for the knock sensor.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-30-2006, 10:47 AM
ariel's Avatar
thnaks for the heads up fourwd1. Will look at that.
thanks al
