Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-29-2006, 12:14 AM
back2life's Avatar
back2life back2life is offline
code #35
i have a 94 suburban 2wd with the 5.7. recently it started idling bad but i kept driving for about two weeks and the check engine light came on. now it will cut off while idling. it runs fine then just breaks down then runs again. pulled code it was a code 35 > cant set idle. i installed new iac motor/valve and ran for a couple days,now back to the same thing. same code again! can some one help me out on what else this could be please!
Old 11-29-2006, 04:55 PM
maxwedge maxwedge is offline
A990 racer
Re: code #35
Code 35 is a map sensor issue., not iac on my list. Check for proper vacuum to map sensor.
Old 11-29-2006, 08:05 PM
back2life's Avatar
Re: code #35
Scanner Definitely Says Cannot Set Idle And Code #35 But I Will Double Check Tomorrow
Old 12-01-2006, 07:04 PM
back2life's Avatar
Re: code #35
definitly #35 code. btw is there anyone that can help?
Old 12-01-2006, 09:48 PM
2000CAYukon 2000CAYukon is offline
Re: code #35
Looking at my factory manuals for my 90 K1500 Pickup is the diagnostic section for code 35:
High Idle - look for vacuum leaks (and check TBI gasket)
System Too Lean - Engine Speed up and down, disconnecting IAC does not help. Check for low fuel pressure.
System Too Rich - Idle speed will be too low. IAC counts will be above 80. Check for high fuel pressure, leaking or stuck injector. Silicone contaminated 02 voltage will be slow to respond.
Throttle Body - Remove IAC and inspect bore for foreign material.
If things improve by disconnecting IAC, recheck all connections and valve terminal resistance.
//2000CAYukon
