Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 09-16-2002, 07:35 PM
DanRico17 DanRico17 is offline
Change headlight help
Alright, I want to change the headlights. All the manual says is go see the dealer. How do i get to the headlight assembly to change the bulbs myself? Thanks.
Old 09-25-2002, 02:57 AM
th0usandaire th0usandaire is offline
Talking
go to any auto store, just tell them you are look for headlight (headlight bulb, what ever tha case is) for a (year, car, model) and they will usually check to see if they have in stock which they should... and then you can change it your self, if you already have the parts i recomend you go buy a HAYNES booklet, it tells you EVERYTHING about your car and how to fix it, it is based on a COMPLETE take apart AND rebuild of your car, the book cost about $10-$17 but its well worth it... but usually if your just replacing the bulb, then you unplug the wire from the back of the bulb, unsecure the bulb from the headlight, and then replace it, and resecure the bulb, and plug the plug back in...
Old 11-15-2004, 01:02 PM
sandiego8588 sandiego8588 is offline
Re: Change headlight help
I need to change both of my headlights also. i have a 1999 Jetta, did you figure out how to do it? any tips? Thanks,
-Jen
changing headlight system from sealed beams to just changing the bulbs candywrapper Grand Prix 2 07-26-2009 10:39 PM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 06:05 AM
HELP Can't remember how to change headlights 88 dakota magillis47 Dakota 0 10-09-2005 08:06 PM
subject about changing headlights AnimeEd Caravan | Voyager 0 12-22-2001 08:44 PM
