Old 11-28-2006, 08:18 PM
prphz prphz is offline
92, Blower motor intermidiatly off and on
I have a 92 Lesabre and blower just goes on & off. It has the standard hvac. not ACC. I replaced resistor, relay, connector to resistor. still the same.
Today when i changed the resistor and connector i turned on the blower & vent button, turned key to on position-- Nothing!! then while i was scratching my head and staring at the blower it started up. . The engine was not on, no vibrations or movement on the car.
Some one please help before i go nuts .
Thx--Eric
Old 11-28-2006, 08:29 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92, Blower motor intermidiatly off and on
Welcome to AF
The next time it does not come on, try bumping it with a hammer. If it comes on then, more than likely the blower motor brushes, or bearings are worn out and you need to replace the blower motor.
Old 11-28-2006, 08:56 PM
Thanks, i will try that. Man i hope thats what it is.
I will update.
Thanks again
Old 11-28-2006, 09:58 PM
spinne1 spinne1 is offline
I had the exact same problem on my 92 and it was the blower motor itself. It drove me nuts until I replaced it (especially on cold mornings with frosted windows and no moving air to defrost it!)
Old 11-29-2006, 09:04 PM
Thanks, it has worked since my 1st post. but i think i will replace it.
Eric
Old 11-30-2006, 10:09 AM
HotZ28's Avatar
AF Moderator Elite
Wink Re: 92, Blower motor intermidiatly off and on
Originally Posted by prphz
while i was scratching my head and staring at the blower it started up. . Eric
An early legend, from back in the “good ole days” was that, Daniel Boon could stare a coon, down out of a tree!
You must have put a fearful stare on that blower motor
to keep it running this long! I also, think it would be wise to replace it.
