Old 11-28-2006, 05:52 PM
busboy4 busboy4 is offline
IMRC'S on later models
Hi All
As an owner of a '96 with a current IMRC problem (front actuator fails to operate/hold vacuum) I was interested to look closely at a '99 and an '01 today. First, Ford wisely got away from vacuum control. On these vans the actuators are electric. Secondly, Ford also wisely designed these controllers to hold the IMRC "Butterflies" in a normally closed position - with power off/failed, the IMRC's are closed where you want them most of the time, and then with high engine RPM, the actuators pull the IMRC's open. On the '96, the vacuum actuators are spring loaded to hold the valves open and thus they "fail" open in the absence of vacuum. I like the newer setup better.
Of course the new ones have the isolator bolt issue, so you win a few, lose a few.
Old 11-30-2006, 12:23 AM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
Re: IMRC'S on later models
I used to own a '96 (now have an '01) and had a ton of problems with the IMRCs on the '96. Sure glad I had a Ford service contract because it paid for itself at least fourfold. So far the '01 is running great with 71K.
*Twin Cities MN*
