Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-28-2006, 06:26 PM
turbo_avenger turbo_avenger is offline
420a engine
on a 420a engine can it handle a 50-75 shot of nos stock????? im rebuildin my engine but if it wont then might as well change some internals........(and im just lookin to run nos at the track maybe 3 times at the most in one night not fast and the furious style every 5 mins)
Old 11-28-2006, 06:35 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 420a engine
Basic answer... No. It technically can, but not for long. You could do that once and blow it up, or it could last forever. Not worth the risk. If you're rebuilding, then swap out internals.
EDIT: And its nitrous... not nos!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-28-2006, 08:11 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 420a engine
NOS is a brand nitrous is a gas.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 11-28-2006, 10:43 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 420a engine
I would say if it was in good shape to begin with and ran healthy it would handle a 50 shot for awhile safely. Granted you have SOME of the basic speed mods and not just nitrous. This is also assuming you have a wet-shot setup.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-28-2006, 11:58 PM
david-b's Avatar
Dave is THAT guy
Re: 420a engine
Wouldn't a dry setup be better with stock?
75 Monte Carlo
Old 11-29-2006, 01:08 AM
Re: 420a engine
From my understanding, dry setup is never better. It's more of a shock to the engine, which isn't a good thing.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 11-29-2006, 01:20 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 420a engine
I wouldnt do anything but direct port. That would be the safest way to do it and if you shop around it should be too bad. Before I got my cams, I came like an inch away from I think either a Zex or NX direct port setup with I think 35-50-75 jets for less than a new wet kit. It was most of a used setup and I think I only had to buy a nitrous solenoid, a line or two, and a bottle or something along those lines, but I think all in all it was going to run me around $500-$550. I would snoop around and go direct port if you can, if not I think wet is the way to go.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-29-2006, 02:16 AM
blk_srt's Avatar
Re: 420a engine
There really isnt alot of difference between a wet kit and direct port. A wet kit sprays fuel and n20 in the intake usually 6" before the Tb whereas a direct port kit sprays it in right by the injectors. dry is gay and you run a better chance of leaning out espically on a stock system. Best bang for the buck is wet IMO and its the easiers to install. Direct port takes more to put in
Mods:
Old 11-29-2006, 04:42 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 420a engine
3 times a night for how many nights is the real question here... Thats some heafty abuse on the motor.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-29-2006, 06:04 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: 420a engine
Direct port nitrous is easy to put on. The tap for the ports comes with the kit, so all you have to do is remove the stock manifold and tap behind each injector on the manifold. Takes like ten minutes.
The hardest part is getting the damn manifold off and on.
I can't imagine anyone using anything other than direct port, it's the best system all around.
1991 GSX 2.3 Stroker
Old 11-29-2006, 10:15 AM
Thor06's Avatar
Jizzed In My Pants
Re: 420a engine
Think about it, wet (or dry I guess but anyone that buys a dry kit is an idiot IMO) kits might not get the correct nitrous/fuel mixture in each cylinder. And correct me if I am wrong, but I think wet kits can puddle up easier in the intake manifold posing the risk for nitrous backfire. I dont know, I wouldnt go any way but direct port.
All this talk about nitrous makes me want to get a smaller turbo and get a 75 shot or something, but that would be more money for the kit, refilling the bottle, more dangerous, and I wouldnt have all the power on tap all the time.
Old 11-29-2006, 12:24 PM
blk_srt's Avatar
Re: 420a engine
The only way I would ever use nitrous is in addition to another power adder and in my case thats a turbo. I dont remember the exact math but its something like for every second you have a 100 shot going you use like 5 lbs on nitrous so refilling your bottle becomes a hassel and expensive if you do it on a regular basis
Mods:
Old 11-29-2006, 01:28 PM
Re: 420a engine
ok well like i would only use it at the track and i only go there like once a month if even that.......... i already have a turbo on it but i wana have a lil extra power if i really need it ......... really the only thing im changin is my pistons which i am puttin forged everything else is basically stock in the kit im thinkin bout buyin ........ really wat internal upgrades should i make to run a 50-75 shot safely?????.......................and also my trans is gettin close to the max hp what kit is the best to make it hold up ........
Old 11-29-2006, 01:41 PM
david-b's Avatar
Dave is THAT guy
Re: 420a engine
No kit for the trans. Just a rebuild or a new one and new clutch.
If you're rebuilding the engine get everything new. Pistons, rods, bearings, crank. May as well do it right. And with using it 3 times in 1 night once a month, still adds up to a lot.
75 Monte Carlo
Thor06's Avatar
Jizzed In My Pants
Re: 420a engine
You are going to need some decent rods for a 420a if you plan on making any amount of power and cams would really help.
