Taurus heater problem
I have a heater problem (1997 Taurus 85,000 miles) . . . no heat/low heat. Im thinking pluged hoses/value or worn pump. The engine temp gauge read normal so im thinking not a pump problem. Before I open the heater hoses I see theres a "T" in the line . . .is there two heater cores? Both look like they go into the fire wall. I read on a priop post there is a . . . by pass hose? I could understand a bypass hose if there was a value to control direction at the Tee but i dont see a value at the tee. Anybody know whats with the hoses? thanks.
Re: Taurus heater problem
there is no heater controll valve on your car hot water flows thru the heater all the time, there is a blend door that moves and directs the hot air to the vents. it sounds like the heater may be disconnected, heater core failure is common on fords
the cable guy |
I have a 98 and two years ago I also had no heat. I took a garden hose and flushed the heater core. I also changed the coolant. The heater worked great so then three months later I did it again just to make sure I had everything clean and would not have to do it again. The wife told me this weekend that the heater doesn't work.
My 98 has a bypass hose and I have been told this bypass hose is to lower the heater core pressure but I'm thinking of plugging this hose. Has anyone done this? |
Just dealt with this on my 99. My temp gauge also read normal. It started out with a bad blend door motor. After I replaced that, I only had heat when I was moving. Replaced the water pump. There was almost nothing left of the blades. I also flushed the heater core when I did that.
I read the Ford TSB recommendations and I just can't justify removing the freeze plugs from the engine to clean out the engine block. I placed a coolant filter in the heater hose going to the heater core and will clean it when the heat begins to diminish. |
