88 RamCharger Shakes at 65+ mph
Not many details other then, when it gets to 65mph or higher it shakes like a mo fo. It has a 5.2L 318ci engine, if that helps.
Re: 88 RamCharger Shakes at 65+ mph
Normally a bad tire or they need balancing. Take it and get the tires balanced, if there is something else wrong they will tell you.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold) HIS----> 2003 Dodge 1500 HEMI QC 4X4 |
But if they were out of balance or bad, they would shake at lower speeds too.
not always. The vehicles that I had shook at higher speeds and not lower speeds. I had a tire out of balance on one, a bent rim on another and a bad belt on another. all different vehicles w/ the same problem and different solutions. your best bet is to have the tires checked, it cost a few bucks, but not much else u can do, unless u have another set of tires and rims u can put on there real quick and check it.
Well, its only a winter beater. I was just curious. I'll probably just let it go.
