Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 11-28-2006, 03:35 PM
junebugs55 junebugs55 is offline
Cool How to fix broken drivers seat 1993 Bronco
My drivers seat's sliding forward and backward --it is broken. Body shop says that is interior work which they don't do. Anybody know how to fix the seat's mechanism? Thanks.
Old 11-29-2006, 08:38 AM
KimMG KimMG is offline
AF - Advisor
Re: How to fix broken drivers seat 1993 Bronco
Compare the passenger seat to the driver's. Replacement parts can be found at a wrecking yard. To remove the seat, move it forward, remove bolts holding the sliders to the floor, then move it back and remove the remaing bolts holding the sliders to the floor. Look at the adjustment mechanism and see why it is not locking into place. http://www.autozone.com/servlet/UiBr...3d800ac8a9.jsp
Old 11-29-2006, 08:58 AM
Thank you, I can do that.
Old 12-10-2006, 08:56 AM
Truck Truck is offline
As you probably figured out, you can't really compare the two side's chairs because the passenger seat has the 'fold-up' mechanism underneath. I have had 'the other' seat problem where you can't get the seat to move. If it's due to the same source, I'd say look under the seat and push the lock-pin switch/slide thing back into the rail, and grease that son-of-a-biscuit until it goes into place by itself.
$.02
Old 12-11-2006, 09:55 PM
Thanks, I'll try your suggestion. You are right --driver's side and passenger's side not comparable.
