Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 11-28-2006, 04:10 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
What are the signs of a bent valve? please help
What are the signs of a bent valve, other than taking about the motor and looking. what performance/riding characteristics come with a bent valve?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 11-28-2006, 06:20 PM
growe58 growe58 is offline
Re: What are the signs of a bent valve? please help
Y'all break a timing belt? A bent valve would likely cause little or no compression in the cylinder. The engine would have a miss and a lack of power. You could also detect the reduced compression with a (ta-da) compression tester.
Trouble is that there are a number of reasons for low compression besides a bent valve. In other words, good compression means that you don't have a bent valve, but poor compression only means that you MAY have a bent valve.
Unfortuneatly the one way to be sure is dissassembly. If you give us more details about the whats and the whys, we may be able to advise you better.
Old 11-29-2006, 04:17 PM
growe i private msged u check it.
