Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-28-2006, 02:03 PM
F!SH 3 F!SH 3 is offline
Speedometer not working
Well last night i was driving home from work on the freeway. going about 85 mph my speedomter needle just dropped and decided not to work. how can i fix this? This is on my 98 GST.
Thanks
96 Eclipse GS Stock
98 Eclipse GST Stock
Old 11-28-2006, 03:12 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Speedometer not working
Did you try taking the plastic panel off and seeing if the needle was just loose? Does it work at all, or does it just stay limp all the time?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-28-2006, 03:57 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
my assumption is gonna be the speedometer gear... it's the little device that sits on top of the differential... they're made of plastic and can be destroyed pretty easily if it misses a tooth on the metal differential gear...
I had one go to shits in the Stealth... I don't think you have to remove the transmission to fix that... just trace the speedo cable outta the firewall to the tranny, pull the sensor and check the teeth... if need be, replace it...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-28-2006, 05:11 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
It sits on top the tranny. You have to take out the battery tray and its right there then. Should be your problem
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-01-2006, 05:21 PM
ok.. i realized that everything works except the speedometer.. the tripometer and i think its the techometer.. so the rpm gas and turbo and temp all work. exept everything thats inside the speedometer.
96 Eclipse GS Stock
Old 12-02-2006, 10:17 AM
Mikelb's Avatar
If you're speedometer doesn't work, neither will your tripmeter. They run off of the same sensor. Everything else should work, they run off of different sources/sensors
