Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-28-2006, 10:37 AM
tobypjmac tobypjmac is offline
2001 Eclipse Headlights
I have a 2001 Eclipse Spyder and I'm trying to replace the headlights. Theres some kind of rubber thing holding the bulb in place. I'm just wondering if anyones done this before and if you just pull this off or if theres another way of doing it.
Thanks
Old 11-28-2006, 10:46 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 2001 Eclipse Headlights
This should be in the 2000+ Eclipse section, so I moved it for you...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-28-2006, 11:55 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
the rubber thing on the rear of the headlight assembly that you said surrounds where the harness goes for the headlight?
there should be a small tab on one side of it, and it pulls right off. may take a little muscle the first time, but it loosens up just like banging on a screen door.
Don't act like you don't love it.
503/2000
Old 11-28-2006, 03:26 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
yeah...if all you are pulling on is the rubber piece and not the wires, keep pulling because you wont break anyhting. Just make sure you arent pulling the harness...I have feeling you will have some troubles getting the harness off the back of the bulb. Just make sure all the little plastic tabs are depressed and then pull like hell (NOT on the wires, only pull on the plastic connector). Good Luck, after you do it once you will feel stupid for asking because its real easy.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-28-2006, 09:20 PM
Sleepr awd's Avatar
i agree, once you figure it out, the next time won't take more than 5 minutes in and out. my first time took me 15 min or so per bulb b/c i had to figure it out.
after you get through the rubber grommit, you need to unhook the wire clip, and it will swing like a door to the side, at which point the bulb will be entirely free.
oh and don't touch the glass on the new bulb. if you have touched the glass, wash it off with alcohol and let it completely dry before you install it. grease and oil from your fingers ( no matter how clean you think they are) is going to cause the bulb to fry within a couple days.
503/2000
