Old 11-28-2006, 01:40 AM
Murphster05 Murphster05 is offline
Backfiring?!?
Ok, so my jeep isn't stock anymore but I hope someone can still help me. I did an axle swap and put a non vacuum dana 44 under the front. After losing my vacuum reservoir and getting a new one, I realized I still had all the old lines from the T case to the front dana 30, so I went and I plugged them all. I plugged the 4 for the T Case plug and the 3 for the front axle disconnect. I then started my jeep and it started better than before, but now at above 3k rpms, it starts to backfire when it drops back down again. Anyone know what might be causing this?
PS - My alternator is dead so it is just running on a weak charge from the battery, haven't gotten the money for the new alternator yet...
Thanks!
Old 11-29-2006, 10:29 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Backfiring?!?
What year is the Jeep and what is the type of that transfer case , Selec Trac ?
The backfire is probably due to battery and bad alternator...
Old 11-29-2006, 12:08 PM
Ok, that is good news then because they are both bad and need to be replaced. It is an '89 Cherokee and I don't remember what the T case number is, sorry, I really should know that. I don't know what selec trac means.
Old 12-03-2006, 12:19 PM
AlohaBra's Avatar
Re: Backfiring?!?
Just a note:
Selec trac and Command Trac are the marketing names for the Jeep transfer case systems.
ST is full time and CT is "part time"...both have been discussed on this forum.
The "Seach tool" can reveal a lot of knowlege and opinions on any topic.
