94 Accord, problem with idle
I have a 1994 accord with the F22B2/non v-tec. I replaced the engine last winter with a used engine from japan with ~50,000 miles. The injectors on the jap engine were bad so I just pulled the ones off the stock engine. I have not been able to adjust the idle on the new engine. I replaced the cap and rotor, plugs, wires, egr valve, map sensor. I finally resorted to forcibly adjusting the idle by tightening up the throttle cable so it idles at about 1800 rpm with the throttle open a little. It will stall when driving sometimes, mostly when I come to an abrupt stop. I was thinking perhaps it could be the ignition coil? but I don't know for sure. Any suggestions? Thanks.
Re: 94 Accord, problem with idle
I'm not certain, but I do believe there is. The ECU is probably different since the model was re-designed in 94. If you're looking for an engine swap you need to find one the same body style as yours. Some of the connections may still be different year to year, EGR valve, MAP sensor, etc., but you can just change over the connectors since the ECU will still read it. I'd try and keep as many of the sensors from the original engine as possible.
by the way I used timming light on mine and adjust the distributor to acquire my idling speed it went down from 1000 rpm to 600rpm. in between 1 and 0 on the odometer. and if you see a small square plastic labeled Diagnose near the intake hose ,open it up and jump the wire E1-T1 before using the timming light un plug a piece of rubber in near the engine block in front. |
Well, DC makes a good product but I don't how important name-brand stuff is to you. I did a quick search on ebay and you can get either chrome or stainless steel headers starting around $65. You can check it out at http://motors.search.ebay.com/92-acc...dQ2cQ20headers
I might just go with that option, because that would ensure that they fit your car and you woudln't have to worry about the fitment from a 94. And if the set he's selling is dented on the downpipe, well it depends how bad the dent is, but it will reduced exhaust flow and could possibly lead to stress fractures in the pipes when you heat them up. |
