Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 11-27-2006, 07:19 PM
EatonZ EatonZ is offline
Valve Cover gasket
I'm going to be replacing the gasket soon and wanted to know if any of you have done this. Is there any thing "special" that I should do, or is it pretty straight forward?
Old 11-29-2006, 01:38 PM
Doug Tatham Doug Tatham is offline
Re: Valve Cover gasket
You will need some blue gasket sealant. On the front side of the gasket there is a place where you switch from the gasket to what looks like a half o-ring. You have to place a bit of sealant on both sides where the materials meet. I advise getting a magnet retriever (not sure of correct name). It looks like a telescoping pen with a magnet on the end. The bolts on the back side of the cover are a bit difficult to reinstall and easy to drop and lose. I put the bolt on the magnet then use the retriever to place the bolt in position, then turn it a couple turns to get the bolt started. I have fairly large hands, you may not have the same problem. If you lose a bolt, remember that they're metric.
Old 11-29-2006, 10:39 PM
alright, thanks for the info Doug.
