Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 11-27-2006, 04:50 PM
ekks ekks is offline
Question 94 Roadmaster rear shocks fully extended?
I came out to the car the other day and my rear end was alot higher than the day before, like the rear shocks were raised/fully extended. How do I lower them back to where they were?
Old 11-27-2006, 11:35 PM
rnj rnj is offline
Send a message via MSN to rnj
Re: 94 Roadmaster rear shocks fully extended?
this should help
http://www.automotiveforums.com/vbul...d.php?t=344759
Old 11-28-2006, 11:07 AM
Thanks for the response...what I get from reading that is if my dump valve is bad I need to replace the compressor?
Old 11-29-2006, 12:15 AM
rnj rnj is offline
I'm sure someone will chime in, but I think it may be something with the height sensor
Old 04-19-2007, 11:36 PM
Windssurfer Windssurfer is offline
It sounds like the dump valve. If you are mechanically inclined you could probably take apart the compressor and clean the insides up. They tend to get gunked up and start malfunctioning. Be careful when you disassemble the area where the air line exits the compressor. Keep this area facing up and be ready for a spring to pop out when you dissasemble this part. Also there is a granular desicant encased inside and could spill out if you are not careful. You should also check the sensor. It is located on the passenger rear above the rear axle upper control arm. Make sure there is a small metal strut from the control arm to an arm on the sensor which senses the height the car is sitting measured between the axle and the frame. You will need the Factory service manual ( worth it's weight in gold) to be able to refer to and check all the above.
