Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-27-2006, 02:23 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
CV axle issues.
Ok, here's the backstory. About 2 months ago, I got into a slight accident where a pickup truck nearly ran me off the road and caused me to understeer into a curb (it was raining). I bent a lower control arm and split open a cv boot. Well I replaced the control arm and the cv axle, which were on the driver's side. But I still didn't get the car realigned. Everything was honky dorry for a bout a week until I noticed an unbearable vibration coming from the passender's side. I'm guessing its the passenger's side cv axle is going bad now. The symptoms are that under steady acceleration in 2nd and 3rd gear, it has a constant "vroom vroom, vroom vroom" sound and feel to it. At highway speeds it does the same. Also, when I turn left a decent speed, it has a constant shake thats more like "vrooooooooom" noise to it. My question is, am I right assuming the cv axle is bad? Or will an alignment cure it? Or both, which is probally the most logical answer.
Thanks in advance.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 11-27-2006, 03:30 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: CV axle issues.
My grandpa's Subaru GL started making the same noise that your car is and it turned out to be the wheel bearing.Good luck dude
Old 11-27-2006, 03:34 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: CV axle issues.
wheel bearings are a BITCH! good luck!
Old 11-27-2006, 04:07 PM
Turbo makes me emo!
Re: CV axle issues.
Oh damn, always fun to hear DSM guys saying something to fix is a bitch. K I'll look more into it, any other opinions?
Edit: I was searching around trying to find out if I need any special tools to replace the bearing, but I never got a straight answer. So dois it possible to change it with just a regular set of tools, or do I have them pressed by a shop. I heard an alignment shop will change those out, and I need an alignment anyways.
Old 11-27-2006, 08:53 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: CV axle issues.
Sounds like wheel bearings...and I think you can just replace the entire hub for not too much...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 12-21-2006, 07:52 PM
Turbo makes me emo!
Re: CV axle issues.
Ok, I decided to bring my thread back up instead of starting a new one.
Here's the update, a week ago I replaced the entire wheel hub, and in the process, replaced the cv axle to (rust-welded, mushroomed the axle bolt beating it out). So here's the deal, my shaking when turning right is cured. However, when I acclerate, I'm still getting shaking that seems to be speed sensitive. When I hit 25-35mph it shakes, and then again once I get to 75 and above.
Here's a few things that may be affecting it. I need an alignmet, after whacking that curb sometime ago, I still haven't gotten it aligned. The other thing is that I have some spacers up front that I had to grind out a bit because they were meant to fit a 4 lug. I don't think it'd be that, but its a possibilty. The last thing is that maybe that wheel isn't balanced, howver I just bought new tires for it about 2 months ago and it was balanced for free. So what do you guys think it may be? I'm hoping an alignment will cure all, but then again, nothing suprises me with this car anymore.
Old 12-21-2006, 10:11 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: CV axle issues.
I dont think not having an alignment would cause it to shake, just maybe drift on you while going straight or premature wear on the tires. If a wheel weight were to have fallen off that would cause your tire to be out of balance and shake. That happened to me once. Also another thing that caused it for my car was by putting a lot of that fix a flat into the tire. During the winter in alaska it would freeze up and my car would shake real bad. Once i finally replaced that tire and got it rebalanced all the shaking went away
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 12-22-2006, 12:14 AM
Turbo makes me emo!
Re: CV axle issues.
Yea I was considering having all the tires re-balanced.
Old 12-22-2006, 12:51 AM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: CV axle issues.
Isn't Alaska fun ? 6 years was enough for me lol.
Anywho, you may have a bent rim also. O.o
2004 Mazda 6i
1997 Tahoe
Old 12-22-2006, 01:10 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: CV axle issues.
That makes me want to spit..
DSM geek
Old 12-22-2006, 05:14 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: CV axle issues.
Either the tire(s) are out of balance or those spacers are not correctly balanced. Get an alignment and get the tires balanced and it should cure all the problems, otherwise you either fucked up something bad when you hit the curb or the spacers are not in balance. But I'm thinking it's the tires out of balance, get an alignment too though, you're probably wearing the shit out of those tires without an alignment, especially after hitting a curb.
95 Talon TSI AWD
97 Eclipse GST
Old 12-22-2006, 08:53 AM
Turbo makes me emo!
Re: CV axle issues.
Its getting aligned and rebalanced after Xmas, and new spacers are being shipped in. I can't believe people try to sell those things for $150 and over, people are on crack these days. To the person who said it might be a bent rim, I already took care of that because the initial wreck broke the lip off. The only thing that was noticeably fucked was the lower control arm (the curved one). So hoping its just unbalanced wheels. I did notice when I first got the wheels, it had sticky weights to balance it, and when I got new tires on them, Discount Tire put sticky weights on top of the other sticky weights. Wtf, lol.
Old 12-22-2006, 07:26 PM
Re: CV axle issues.
Tell them you want them balanced statically (with the sticky ones), not the old fashioned way with the weight on the outside.
95 Talon TSI AWD
97 Eclipse GST
Old 01-29-2007, 05:01 PM
Turbo makes me emo!
Re: CV axle issues.
Well I thought I'd bring this back up instead I starting another one. Well I've replaced my front-right wheel hub assembly twice (the first one was faulty), and I've still got that shake under acceleration and highway speeds. A friend of mine was saying it could be a tie rod gone bad also. I've never messed with one of those before, but I'm gonna take a look at it eventually to see if anything's out of the ordinary. You guys have anymore ideas on what it could? Everything's been balanced and aligned, so its gotta be a part somewhere no acting right.
