Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-27-2006, 11:43 AM
kranky411 kranky411 is offline
99 ford contour tail light
on the right side my tail light does not work, blinker and brake light works also the front right running light does not work, should i look for a fuse which fuse would it be? thanks
Old 11-27-2006, 06:30 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 99 ford contour tail light
sounds like a wiring issue. There isnt a fuse for individual sides.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-27-2006, 10:29 PM
jsweeter jsweeter is offline
most cars utilize two bulb lights in one housing. One is for the brake light and the other one is for the blinkers and such. Change the bulb. Probably the same issue up front.
