Car wont start....
My car is not starting... Its not the battery/fuel/spark.
Wont even try to turn over, let alone make the little click noise the starter does... Im thinking its the Ignition Switch... any ideas?
![]() Upgrades... To many to list...
Re: Car wont start....
how many miles are on the car? do you have a heavy key ring/chain? check the eci fuse? how about the PTU?
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
It was the ignition switch
