Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-27-2006, 01:56 AM
Falcon1987 Falcon1987 is offline
Anti-lock Brakes
I have a 98 Sierra 1/2 ton 4x4 and I was driving around in the snow today and for some reason the abs kicked in while I was braking. I had light pressure on the brake pedal, I was just easing it on and the abs kicked in.
Is this normal for driving in slippery conditions?
Also, what determines whether or not the abs kicks in?
Old 11-28-2006, 11:18 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Anti-lock Brakes
ABS is activated when the vehicle speed sensor (vss) senses the wheels are locking up under braking conditions. There is a motor or pump that pulsates as you would on an older vehicle that doesn't have abs. The vss sends a signal that the wheels are locking up to the abs controler or bcm and it tells the abs pump to activate. Hope this helps.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
