Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 11-26-2006, 11:14 PM
x3xdelsolx3x x3xdelsolx3x is offline
4-point racing harness
i have a '93 del Sol and i purchased racing seats with 4-point harnesses as well. the seats were a pain in the ass to mount because i used the brackets from my stock seats and tore it all apart to fit the new seats. i was wondering about installing the harnesses. is there a pre-existing hole for each point to be screwed into, or do i have to drill and tap new holes to mount the belts?
Old 11-27-2006, 01:34 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: 4-point racing harness
To properly install them they would need to be anchored to welded in plates; or to a roll cage. You dont need them for street driving, and in most places it will be illegal to wear while driving on the street.
Old 11-27-2006, 01:42 PM
...but if i wanted to install them?
Old 11-27-2006, 01:58 PM
Forunn Daberator
You could be like all the other ricers and drill holes and your floor and put a regular bolt though it. It wont protect you against much, as it will rip out of the sheet metal.
Old 11-27-2006, 11:36 PM
any other suggestions anyone?
Old 11-28-2006, 11:51 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
take it to a welding/fab shop and have them either weld in plates for you or fabricate a harness bar for you... pricey, but it's the only way to really stay safe in them.. make sure the shop is an auto welding shop, as well.. they would be up on SCCA/NHRA safety specs, as well as knowing the proper mounting angles, etc, for harnesses. An improperly installed harness can break your back in half in a wreck. I'd rather shell out more money now and get them installed correctly than spend a CRAPLOAD of money in the hospital getting my back put back together.. kapische?
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 11-28-2006, 06:05 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Also in most states you have to have the origanial seatbelt to pass inspections so don't rip that out if you want to stay legal.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
