Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-26-2006, 09:06 PM
Michael Newton Michael Newton is offline
Unhappy '89 Camaro Problem with vibration when braking at certain speeds! help!!!
I am having a problem with a vibration when braking at certain speeds. Doesn't always seem to be in the front or back. I changed my rear drums and pads recently, thinking this was the problem. It didn't help. It seems if it was rotors, it would be at all speeds, but it seems to be worse around faster speeds when braking (55-70 m.p.h.). Does anyone have any suggestions?
Old 11-26-2006, 10:30 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: '89 Camaro Problem with vibration when braking at certain speeds! help!!!
Welcome to the forum.
Check the tires. Change a spare tire on to it and drive it , and check them one at a time all the way around until you find wich one it is (if any).
If its not that check the tie rods, front end bushings, ect on the steering.
Good luck.
Old 11-26-2006, 10:32 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
maybe you need your disks lathed, if they're warped or something they won't really run true, and that causes vibration.
Seatbelts Saved My Life
Old 11-28-2006, 02:18 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Sloppy torquue converter clutch disengagement? Just a thought
Old 11-28-2006, 07:23 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Does it go to one side or the other when you brake? Rotors are probably warped, I had that with my 92.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
