Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-26-2006, 09:00 PM
gelcol gelcol is offline
Smile do contour have timming belts?
like the japanese cars? coz I need to replace a water pump which making a noise .
do I need to replace a cam shaft seals, tensioner?
how much do the shop charge? for these ?
t.y.
Old 11-26-2006, 09:49 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: do contour have timming belts?
what engine you have would help. im assuming its an I4?
but to answer your question, I4 uses a timing belt. The V6 uses timing chains. On the V6 the waterpump runs of a serpentine belt while the waterpump on the I4 (dont quote me on this since I dont have an I4) runs off the timing belt.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-26-2006, 11:44 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
water pump on zetecs is ran by serpentine.
Only zetecs have timing belt.
400$ or more to have a shop replace the belt,
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-27-2006, 09:30 AM
Smile Re: do contour have timming belts?
All I know is a 1999 v6 its my friends car so is this used by a belt? or chain?
how many hours to change a water pump ? and how much do they cost?
thankz
Old 11-27-2006, 09:43 AM
thankz
its driven by a serpentine belt. Takes about 1 hour to change. New waterpump costs ~$80. Make sure you get the one with the metal impellar.
"The CEG Nazi"
www.contour.org
Old 11-27-2006, 09:48 AM
serpentine belt how to uninstall pls give me a instructions on how to unistall the belt and water pump,what is metal impellar? Thankz!
