Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 11-26-2006, 08:11 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
whats next for my srt-4?
i got my srt-4 last december and since then i got i have put in short ram, koyo radiator, 3 inch cooler udgrade, and greddy blow off. oh i also took off resinators and i putting in 3 inch downpipe this week.
my problem is that i want the stage 2 upgrade. ive been told that i can upgrade computer without injectors or wastegate and the whole kit.
does anyone know if its possible to upgrade with just a stage 2 ecu without the whole kit???
thanks
Old 11-26-2006, 08:37 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: whats next for my srt-4?
thanks
Why would you want to do that though? Just keep it s0 or possibly even s1...You don't need s2 to make the power...Just do an fpr mod and mapclamp with an agp wga and call it a day...
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 11-26-2006, 08:49 PM
MrCrazy's Avatar
to tell you the truth i dont the that lingo. fpr, mapclamp, apg, wge. can you be a little more specific plz. i was kinda new when i bout my srt-4.. but learned what i could for my mods that i got now...
Old 11-26-2006, 09:40 PM
TEXSRT4 TEXSRT4 is offline
just buy the stage2 kit. you will want all the parts anyway.
Old 11-26-2006, 10:20 PM
Turbodog97's Avatar
Just a Neon
It just depends on if you are trying to be cost efficeint...
05 Srt4
97 Mx-5
Old 11-28-2006, 12:00 AM
ccopriviza ccopriviza is offline
Send a message via AIM to ccopriviza
you seem to be the most knolegable person on here about the srt4's. I'm still knew to this too and could use some advice about what I should do with my car.
Old 11-28-2006, 12:09 AM
Turbodog97's Avatar
Just a Neon
That all depends on where you are trying to go with it...List your goals and I can give you some suggestions, also price ranges...because I don't know about everyone else on this board but money is the enemy when it comes to my car...and boost leaks
05 Srt4
97 Mx-5
Old 11-28-2006, 10:22 PM
TeamNemesis3 TeamNemesis3 is offline
does anyone know where I can get some HID for my SRT-4 headlights and fog lights? or should I just get the BLUBS??? is it really that big of a difference? thankx guyz...
SRT-4
**Mod'zzz**
Mopar BOV
NGK Iridium IX
Mobil 1 Oil & Filter
Old 11-28-2006, 10:31 PM
Turbodog97's Avatar
Just a Neon
http://quickwhips.com/store/index.ph...1affc8dc23f916
05 Srt4
97 Mx-5
Old 11-30-2006, 01:52 PM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
mid-as-well get bulbs....friend of mine just payed 225 for a HID kit and the bulbs prob run alot cheaper...
ThE neW wHiP:
Old 12-02-2006, 12:31 PM
teaminterlude3's Avatar
teaminterlude3 teaminterlude3 is offline
hey, guyz...I was just wonderin'.... how many quarts of OIL...do u guyz use on ur SRT-4???
cuz I just did my oil change and I think I might of put a bit more...5 quarts!! of MOBIL 1 5w-30.... OIL JUST LOOK'S A LIL OVER full...should I drain some oil or I'm I FINE?? thankx guyz
SRT-4
**Mod'zzz**
Mopar BOV
NGK Iridium IX Plugs
Mobil 1 Synthetic Oil & Filter
Apexi Turbo Timer
Old 12-02-2006, 03:19 PM
5 quarts is what you should need, of course depending on teh capacity of your oil filter and whether or not you have done some motor work
Old 12-02-2006, 04:23 PM
Turbodog97's Avatar
Just a Neon
If it's not too much, and if you have a catch can, it will work it's way out of the system over time. But if neither for both, just drain a small bit out at a time until it looks good. It's always best to be a little short and add more than be a little over.
Edit> What I always do, is add 4.5qts immediately. Wait about 2 days, and add the rest(if needed).
05 Srt4
97 Mx-5
Old 12-02-2006, 07:19 PM
..thankx guyz...I waz lookin' over my handbook...N I found...that they do take 5 qt. thankx...anywayz guyz...
SRT-4
**Mod'zzz**
Mopar BOV
Apexi Turbo Timer
Old 12-22-2006, 05:54 PM
87BoxClassic's Avatar
87BoxClassic 87BoxClassic is offline
when you install a stage 2 comp on a srt-4 it's gives you power but makes it run very poorly, my friend did it to his and now he needs new fuel injectors it overloads them and they can tspray as much fuel so it sounds like it's mis firing
