Old 11-26-2006, 05:26 PM
pearlheartgtr pearlheartgtr is offline
88 Cherokee EGR Valve Removal
Hey all!
I have a 88 Cherokee 4.0L 4x4 and I need to get the EGR valve off. It seems almost impossible. I can't get in there with even the smallest torx driver (1/4 inch). Anyone have any suggestions on how to get the valve off?
The problem I am having is that it stalls or bogs down when I turn or apply the brake. I've changed the O2 sensor (that was an adventure in of itself), the brake booster, and the IAC valve. It seems fine for a few hours then the stalling starts again. The last thing I can think of is the EGR valve. But before I spend $80 on that, I want to take it off and try cleaning it out.
Thanks for any info you might have.
Old 11-27-2006, 03:33 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Re: 88 Cherokee EGR Valve Removal
Changed one on my 89'...wound up using like 2 swivels and a combo of some different extensions.....I don't think there is an easy or sensible way to remove it....
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Old 11-27-2006, 04:47 PM
Ah, so I basically have to make a contraption to remove the contraption.
Thanks!
Old 12-03-2006, 03:56 AM
Stick89's Avatar
2 torx bolts...remove the windshiel washer bottle....if you have MPFI remove the air intake hose that goes to the throttle body....give ya a little more room
