Old 11-26-2006, 04:40 PM
jeremy87may jeremy87may is offline
S10 problems?
My name is jeremy and I have a manual transmission 1998 s10. When backing up in my truck, it will stop and either come out of gear or not completely go into gear. Sometimes when coasting down hills, without giving gas, it will pop out of 5th gear and I have to push clutch in and apply gas to get it to stay back in 5th gear. any help?
Old 11-26-2006, 05:47 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: S10 problems?
My limited knowledge of manual transmissions would lead me to believe it could either be a linkage (shifter) issue or a synchro issue. Someone else can give you more info I am sure.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-26-2006, 06:11 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: S10 problems?
Where the shifting stick goes into the transmission thee usually is a plastic cap on the end of it.
Pull it out and see if it is still there.
Also with shifting stick out reach in there with a big screwdriver and push the shift rail in gear and see if if snaps in gear good.
If it snaps in gear good there the problem is internal.
Might be time to have a good repair shop check it out.
MT
Old 11-26-2006, 11:30 PM
Blue Bowtie's Avatar
Registered Offender
Re: S10 problems?
Is this behind a four-cylinder (NV1500 transmission)?
