Old 09-16-2002, 01:04 AM
RX7FD's Avatar
RX7FD RX7FD is offline
Question Need Help with primer
Hey guys, I have been making models for about 4 years now, and I have never painted the bodies myself, whenever i try this, the primer is too thick, i do not have an airbrush so i use the can. When i primethe body the primer is really thick and covers up all the panel lines. So every model i make my friend paints it without primer sometimes it turns out good sometimes not so good, also im not that good at painting the body either i dont put enough paint or too much. It does not say anything in the FAQ about the primer being too thick, can anyone help me out.
Old 09-16-2002, 03:08 AM
djmr2's Avatar
djmr2 djmr2 is offline
what kind of primer do you use???
get some krylon sandable primer from walmart or something
u gotta spray in light coats... START spraying OFF the model and move across it.. and so on..
Old 09-16-2002, 03:53 PM
Jay! Jay! is offline
Horizontally Opposed
Welcome to AF! Where are you in the world? That'll help us help you figure out what products you should be able to find locally...
Hierarchy of Subaru:
(Click to see mine!)
Old 09-16-2002, 06:35 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
I've used this stuff on a couple of models. though i think its sufficient for bodies and exterior parts, it has a nasty habit of flaking off when i use it to prime the interior. what i mean is that when i use flat paints over it, they dont seem to stick well to it. the slightest touch will scrape off the flat paint to show the primer below. its quite annoying, especially if you painted the interior with a mixture of different colored paints that is hard to recreate. i guess what im trying to say is krylon is ok for gloss paints but not flats... in my experience at least.
Old 09-16-2002, 06:39 PM
RX7FD's Avatar
I use model master primer, i live in the northwest chicagoland area if that helps, thanks for your input.
Old 09-16-2002, 07:46 PM
daggerlee's Avatar
I used Krylon sandable white primer for everything except the body of a kit...don't know what's happening to you COSMO, as it works just fine for me... But I highly recommend it, it's only $2.50 or so for a 12 ounce can. Goes on a little thick though.
For kit bodies I desire a smoother finish so I use either Tamiya white primer (make sure to use the white the grey is a coarser grain) or Mr. Surfacer 1000..
Dan
help with primer and clear parts mr_tomcat123 Car Modeling 2 08-12-2008 08:38 AM
Need Help With Primer redhotstang00 Cars in General 1 10-18-2006 04:31 PM
got started with some models, now need help with painting gigglesnirt Car Modeling 4 01-02-2005 01:55 PM
Need help with some major problems with 95 probe Feicht Probe 5 09-10-2004 01:33 AM
Custom CRX WIDEBODY, Need help with rims. Need some input. Psionic '88 - '91 Civic | CRX | Wagon | Shuttlee 12 12-19-2003 12:43 PM
