Old 11-25-2006, 08:48 PM
modelt1953 modelt1953 is offline
1987 escort
This car was not firing so i replaced the ecm relay .Now the car will fire but the fuel injector is not getting fire to it.It was working before.Any ideas.thanks
Old 11-25-2006, 11:02 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 1987 escort
What you are saying is, you were not getting spark and you decided to change the ECM. After doing so, you now have spark but no power to your injectors?
Why did you change the ECM? How do you know you are now getting a spark? How do you know the injector is not receiving a signal?
Old 11-26-2006, 06:50 AM
Re: 1987 escort
[quote=mightymoose_22]What you are saying is, you were not getting spark and you decided to change the ECM. After doing so, you now have spark but no power to your injectors?
Why did you change the ECM? How do you know you are now getting a spark? How do you know the injector is not receiving a signal?[/
I didn't change ecm.I changed the ecm relay.Put it this way.It will shock you real good.I tested the injector wire with a noid light.No fire.
Old 12-10-2006, 03:29 PM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
Re: 1987 escort
You can check for spark by pulling the spark plugs, keep them connected, and crank the engine remotely. You can watch the plug then, and see if there's spark. Also, finding a simple spark checker is cheap and easy. The best way I've found of checking the power for a fuel injector, especially on CFI, is to just use a typical 12v ford dash light, and plug it into the injector connector. If it is pretty dull looking when you try to start the car, then you're fine. If it's bright, like a normal 12v light should be, then you have too much voltage going to the injector, and if the light doesn't turn on, then you don't have voltage going to the injector, in which case you should start tracing the wires back to the ecu and see if anything is burnt/melted/having high resistance.
