2003 silverado 4.8no compression?
I just purchased an 03 silverado it will not start. I pulled the spark plugs and they look good (used not new) I checked the compression and it has from 25 to 75 psi. Does G.M. still use fiber coated camshaft gears or do I have big problems? Thanks Jerry
Re: 2003 silverado 4.8no compression?
pull a valve cover and see if the valves move. if so, then big problems. if not, start with timing chain.
I pulled valve cover and rockers are moving plenty. I loosend them off a couple of turns no help. I squirted oil in one and comp came up from 60 to 70 on a good cyl.
how many miles on the engine, and what condition was it in before this happened....was it running rough, or just up and died with a no start?
Before you torture yourself here, make sure you have spark and fuel pressure that gage may be wrong or the engine cranks too slow or you are not holding the throttle open.
I'd do a leak down test on the engine and see what you come up with, seems hard to believe the engine would loose this much compression on all the cylinders, if you bring the engine up to tdc on #1 you should be near the mark on the damper. If the valves are stuck/not seating you will hear the air escape from the intake or exh.
if its a bank repo chances are the previous owner gernaded it before they came and got it. or did something to destroy it.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician Master Certified Emergency Vehicle Technician Law enforcement Vehicles |
Makes you wonder what the rest of the powertrain is like. Make sure you measure up the crank and bore with proper instruments to make sure nothing is out of round and taper within tolerances. If you're this far into it, i'd definately do a complete overhaul.
