Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-25-2006, 03:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Exclamation Bad Outer Tie Rod
I went to get an alignment yesterday on my car bc I got new tires a couple days before that. After waiting 3 HOURS, they finally took my car. While putting the weights on, the passengerside front wheel would move when it wasn't on the ground. After they looked and it and checked everyth4ing out, it turns out to be a bad outer tie rod. This does finally explain the popping noise that the car has made since I bought the car. Good thing is that they quoted me $160 for replacement, alignment, and everything. Not too bad I dont think. Only problem, it takes 3 hours to do it. With the holidays, I don't have 3 hours. Working a ton of overtime the next couple weeks and still got school. Oh well. It'll happen soon enough though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-25-2006, 03:05 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Bad Outer Tie Rod
You could do it yourself, it's not that bad. If you wanted to that is.
1991 GSX 2.3 Stroker
Old 11-25-2006, 03:33 PM
david-b's Avatar
Dave is THAT guy
I'm not a big fan of doing my own suspension work. Especially something like that. And plus I need the alignment anyways, so might as well get it all done together. Plus it has a warrenty then too.
75 Monte Carlo
