Old 11-25-2006, 02:15 PM
cnibs cnibs is offline
oil leaks
seeing & burning oil odor @ idle. are they any common oil leaks on the accord. thanks cnibs
Old 11-26-2006, 12:37 PM
somick's Avatar
somick somick is offline
Re: oil leaks
When you replace oil filter oil pours right on the exhaust pipe.
If your filter is not tight enough that might be one of the spots.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-27-2006, 02:16 AM
mpumas mpumas is offline
Re: oil leaks
Valve cover gasket can also cause a buring oil smell. Wash down the engine when it is cold. Use a strong degreaser or solvent and then rinse with water. After driving it for a couple miles look for new oil around the gasket.
Old 11-28-2006, 04:59 PM
Re: oil leaks
I cleaned the engine over the weekend. So far, no complaints from the little woman but will check this weekend for any fresh oil from valve cover.
Thanks for you help
cnibs
Old 11-28-2006, 05:01 PM
Re: oil leaks
I will check the oil filter, the little women had the vehicle serviced at a quick lube place recently.
Thanks for your help,
cnibs
Old 11-30-2006, 11:31 PM
AcuraTL2005's Avatar
AcuraTL2005 AcuraTL2005 is offline
Re: oil leaks
what year accord?? older accords are known for rocker shaft seals, dizzy o-rings, and oil psi switches...ok yeah...opg's 2
Stop Cyrin, Start Tryin
