Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-25-2006, 11:50 AM
firesdoom's Avatar
firesdoom firesdoom is offline
Send a message via AIM to firesdoom Send a message via Yahoo to firesdoom
Removal and installation of 1G driver side lower ball joint.
Alright, the Haynes manual says it's impossible and I need a control arm. Autozone and some other sources say otherwise. I recently busted my DSM CD and I need to know how you remove and install the ball joint.
Black 92(6 bolt) Eclipse Auto N/T 2.0
K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers
1990 AWD Astro Van
Don't mod a car with problems. Don't swap parts without testing them.
Old 11-25-2006, 06:44 PM
firesdoom's Avatar
Re: Removal and installation of 1G driver side lower ball joint.
Well after at least three hours of labor it looks to be back on. Should have had snap ring pliers. Should have taken out the axle to impact the nut. I didn't realize there was a snap ring there so I bent my control arm a bit. Don't really know how bad. Now I need to take the axle off to impact the nut back on. I'll have to do that tomorrow. I'm so glad I broke my DSM cd, the Haynes manual won't tell you how to do it, and you guys couldn't give me anything.
1990 AWD Astro Van
Old 11-25-2006, 10:32 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
you need a whole new lower control arm and that should cost you around $130
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 11-26-2006, 02:16 AM
firesdoom's Avatar
I think the junkyard will give me something a little more reasonable than that. I'm not gonna try driving an hour away to the dealer in a fucked up astro van. Right now it's three in the morning and I'm late for work and I'm trying to disconnect the axle from the steering knuckle so I can use the impact to tighten the ball joint nut. This shit fucking sucks.
1990 AWD Astro Van
Old 11-26-2006, 03:50 AM
firesdoom's Avatar
Well it didn't work out. I never could get the snap ring in there perfect because the control arm is bent from trying to press the ball joint out without removing the snap ring. I've checked a lot of posts on ball joints and nobody mentions a snap ring.
So, when I get the new lower control arm on how do I tighten the ball joint nut? It seems to me like you would have to remove the axle so you could get an impact on it. But how would you get the axle back on when it's tightened though? Doesn't seem possible. Can you jack up the control are by the ball joint and tighten it? Will that work?
I really need to know how to tighten the ball joint nut.
1990 AWD Astro Van
Old 11-26-2006, 10:43 AM
blk_srt's Avatar
Dont you have a parts store around you? you dont need a dealer. I have no idea what snap ring your talking about
Mods:
Old 11-27-2006, 11:23 AM
firesdoom's Avatar
Parts stores don't sell the lower control arm for this car. The only options are dealer or junkyard. There is a snap ring that holds the ball joint in place. It's there...trust me.
1990 AWD Astro Van
Old 11-27-2006, 02:41 PM
blk_srt's Avatar
I just called advanced auto and they have 2 lower ball joints in stock for your car and they are less than $40 and that is without my discount. And carquest has the control arm for $197 and I think that includes the ball joint. If you cant find it you obviously arent looking to hard. If you want I will order the parts for you and ship them if you give me the money for everything.
Mods:
Old 11-27-2006, 05:56 PM
firesdoom's Avatar
$197 is more money than I'll have in two weeks. I got a control arm at the junkyard for 35. Put it on and realized that the threads on the ball joint are fucked up. Now I gotta get a shop to put in the new ball joint because the autozone tool doesn't fit the control arm properly. The advance one is more money to rent than I have.
1990 AWD Astro Van
Old 11-27-2006, 06:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Check www.rockauto.com. They have good deals and a huge ass selection of some of the most random shit in the world. Check there, you will have to wait for shipping but right now buying a new one is going to be better than continually dumpin money into cheap ass parts/tools that arent doing you any good.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-28-2006, 01:29 AM
blk_srt's Avatar
Mods:
Old 11-28-2006, 07:10 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
I'm not sure why you say he needs a whole new control arm, i had my talon and baljoint went and i pressed it in and put the new snapring in and grease boot...problem solved 13.99$ from my parts store
Old 11-28-2006, 11:13 AM
blk_srt's Avatar
because he forgot the snap ring and bent the whole arm while he was trying to press it out
Mods:
Old 11-28-2006, 11:53 AM
firesdoom's Avatar
Speaking of cheap ass tools my 14 wrench broke yesterday on the sway bar end link. Thanks for the link, I might order something from them when I have a back up car to drive. Right now my biggest concern is having a working car. I like to buy the best parts in my price range for my car when I can. Right now I'm lucky to be getting by though.
1990 AWD Astro Van
Old 11-28-2006, 05:19 PM
firesdoom's Avatar
Well I got it all back together...mostly.
I'll have to drive to work without a sway bar end link.
Let me add that the best way to attach the ball joint to the steering knuckle is by taking the whole control arm off. That way you can put the ball joint in the knuckle and put the nut on it to protect the threads as you attach everything else. Just thought I'd share that since I haven't seen anyone mention it.
Thanks for the help dudes.
1990 AWD Astro Van
