Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-25-2006, 08:53 AM
Ramblin Fever Ramblin Fever is offline
DPFE sensor - anyone heard of this IN
an Isuzu engine?
Dreaded CEL is back on, but the truck is actually smoother then when the CEL is off - this is getting extremely irritating.
Same code P0401, I'm sure everyone knows by now that I've replaced the EGR valve, cleaned those pipes a million times, cleaned the TB, reset the computer so much that the bolt on the negative battery needed replaced last time.
Per Tynan's Isuzu in Denver, the Isuzu engine does not have a DPFE sensor, but I've heard rumors that this 3.2L *may* in fact have one. And also, if it does have one, where can I find it, dealership, Napa, and autopartswarehouse (internet) doesn't carry one for Isuzu engines.
Also does anyone know what else could be linked to the EGR insufficient flow reading? Any other sensors, i.e idle air control, temp sensor, etc.
I know the MAP sensor *could* be related, but I've also heard that it would throw it's own code.
FWIW - all wiring connections are reading fine.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 11-25-2006, 10:29 AM
df2000 df2000 is offline
Send a message via AIM to df2000 Send a message via Yahoo to df2000
Re: DPFE sensor - anyone heard of this IN
I think DPFE sensor require vacuum line to go to EGR but '97 EGR all electrical.
There is 15A fuse for ECM in engine bay fuse box(look on top of the box it say ECM), by removing this fuse it will reset the CEL also. But the code(P0401) is still be stored in ECM memory and you need 40 cold starts with no failure to remove it from memory. So if say you do 3 starts a day you need about 2 weeks without code and you can pass inspection.
And now VERY wild guess... May be problem is in your ECM. Not sure what you can do unless you have second good ECM and you can swap them to check it out.
Old 11-25-2006, 10:59 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by Ramblin Fever
an Isuzu engine?
A DPFE sensor is a exhaust back presser sensor.
Unless your engine has one ???
The map sensor tells the pcm when to open EGR valve
Ford used them and had a lot of problems with them.
They are usually connected to the EGR valve exhaust tube or pipe with small hoses.
Post your year and model and engine and I will check for info on it.
Your code indicates not enough egr valve flow.
Also check for egr valve passage stoped up.
MT
Old 11-25-2006, 02:33 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Originally Posted by Rambliln Fever
... I've heard rumors that this 3.2L *may* in fact have one. And also, if it does have one, where can I find it, dealership, Napa, and autopartswarehouse (internet) doesn't carry one for Isuzu engines.
what exactly would it take for you to believe that it does not have one? i know -- let's start a rumor that it doesn't have one.
really Ramblin Fever, you spin your wheels way too much when the answer's there in front of you. you don't have one. move on and figure out what's really wrong.
my guess is that when the CEL is thrown, the computer is putting itself in the closed loop mode and that's why it seems to be running better, although the problem hasn't been fixed. {{actually it might be putting itself in the open loop mode, i never get these loop terms straight }}
iirc, there's a whole diagnostic tree in the helms factory manual about troubleshooting this kind of thing.
hth
the above is rumored to be from
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 11-25-2006, 02:47 PM
MT-2500's Avatar
AF - Advisor
an Isuzu engine?
Well you are lucky it looks like it only has a MAP sensor and no DPFE like a Ford.
Here is a PDF that tells you how to.
http://members.troublecodes.net/crunch/401isui.pdf
Let us know how it goes.
MT
MT
Old 11-25-2006, 08:44 PM
rodeo02 rodeo02 is offline
Rambin, I'm getting mixed up now since you have several threads going on for the same EGR issue.. IIRC, you said you had a strong vacuum from the EGR valve base with the vlv removed and the truck idling, correct? I dont recal you going into detail on any exhaust flow pulsing out of the exh port on the EGR base (at idle). You need to feel/hear a pretty decent amount of exhaust popping out of there. It should sound like an exhaust leak with the valve off and the truck idling. You can stop up the flow easily with your finger/rag, but it needs to flow freely for the system to work.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-26-2006, 12:39 AM
Trooperbc - this is the 1st time someone from THIS board has in fact said it didn't have a DPFE, but, some FROM this board have also said that it may have one - I was in fact asking.
Spinning my wheels, what is that supposed to mean and If YOU in fact know the answer, as you said it's right front of me, then what is it that's causing this P0401 code?
Move on to WHAT's really causing the problem, you stated, my answer is WHERE have you been - if you haven't read it before, I have done just about everything there is to do for a stupid P0401 code, THIS is why I'm asking if any other sensors are related that I may have missed.
MT-2500 thank you VERY kindly for your input; I will look more into the MAP sensor area and double check all the wiring.
Rodeo02 sorry for all the confusion, I only started another thread cause I simply wanted to know FOR SURE if anyone in fact knew it had a DPFE sensor. Both EGR holes, little and big, are good and clear at idle - little one has good suction, big one has exhaust coming out and yes, it sounds like a major exhaust leak with the valve off.
We will double check all wiring going to the MAP sensor tomorrow, after this, when we're off at X-mas, I'll have the mechanic fumble with it - probably some stupid $20 part.
1997 3.2L V6 Rodeo
Old 11-26-2006, 08:56 AM
MT-2500's Avatar
AF - Advisor
You are welcome.
Print off the pfd I posted and go threw it when time permits.
And remember the old map sensors need good vacume and engine running good to work right.
Good Luck and let us know how it goes.
MT
MT
Old 11-26-2006, 09:42 PM
Problem resolved - thank you all very greatly!!
1997 3.2L V6 Rodeo
Old 11-26-2006, 11:50 PM
trooperbc's Avatar
ok Ramblin, maybe i was a little harsh. all my comments were directed at the DPFE and lack thereof. you wrote that 3 or 4 places, including the dealer, told you that no, your truck doesn't have one. my "spinning wheels" comment refers to you not accepting their answer, as does "right in front of you".
as to where i've been -- i really don't spend a lot of time trying to piece various threads together, but i did have a very real, though vague, sense that i've heard all this rumor stuff before -- hence my frustration. and i offered my one contribution. . .
glad you resolved the problem -- how, exactly, anyway?
//bc
Old 11-27-2006, 05:42 AM
Ramblin, you gotta be kidding. Enough bandwidth used up on this topic to computerize a third world country and you sum it up with "Problem resolved"!!!! C'mon man! Spill the beans! (funnin' ya man!)
Joel
Old 11-27-2006, 08:37 AM
MT-2500's Avatar
AF - Advisor
You are welcome and glad you got it fixed and thanks for posting back the fixed.
But would you give us a hint on what the fix was?
It may help somebody else with the same problem.
MT
MT
Old 11-27-2006, 05:29 PM
surferfletch surferfletch is offline
C'mon man! Are you going to charge for the fix?!?! PM available after PayPal payment!!!?
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 11-27-2006, 06:51 PM
Ahh, but it's SOO very fun keepin you all in suspence.
Seriously, I meant to reply further on the resolution at the time, but we had a very very mean intruder that suddenly became obvious in our basement that was MUCH more important then a reply.
One of our little dogs got himself cornered by a baby rattlesnake - took a bit to figure out how to get a hold of both without either making contact.
Rattlesnake in the wintertime - man, we got bigger problems then I thought!!
The fix on the truck involved 2 sensors that obviously do not always give out their own codes - the map sensor was definitely a gonner, along with the idle air control sensor.
Tried cleaning the idle sensor, it was just too gummed up. Can't complain, two sensors together weren't too bad considering they'd never been replaced or cleaned before.
Sorry for the separate threads in all this, it's just I wanted to make it obvious that the P0401 code isn't always resolved JUST by cleaning or replacing the EGR valve. Nor is it a simple fix that everyone has answers to.
1997 3.2L V6 Rodeo
Old 11-27-2006, 07:45 PM
MT-2500's Avatar
AF - Advisor
Glad all is well.
Little dog and truck.
And we hope you took care of the rattle snake to.
But keep a eye out for them more baby rattlers for sure.
And watch out for mama and papa rattler.
I was raised with copper heads coming into the house.
Which are a lot sneaker than a rattle snake.
A old rattler will usually stay more out in the open and give you a warning before biting but a old coper head will hide under stuff and just just go ahead and bite if you get to close to him.
So I know the feeling.
Thanks for posting back fix.
MT
MT
