Old 11-25-2006, 02:12 AM
fwellingtonfiii's Avatar
fwellingtonfiii fwellingtonfiii is offline
4 channel amp??
Hey everyone.
Well, too start off, I've got a Sony Mobile ES XM-7547 (http://www.carreview.com/mfr/sony-st...5_1806crx.aspx) , and I don't understand the meaning behind the four channels stuff. Ive got the amp hooked to two Alpine Type R 12's, the two ohm edition, and they just dont seem as loud as they should be. The power is ranked as so...
Max. Power Output* (4Ohms)
- 4-Channel: 180W x 4
- 3-Channel: 180W x 2 + 600W
- 2-Channel: 600W x 2
Rated Power Output (4Ohms)
- 4-Channel: 75W x 4
- 3-Channel: 75W x 2 + 300W
- 2-Channel: 300W x 2
Im new to car audio, so Im trying to learn. My question is, since I dont understand the channels thing, how can I set up my amp to get the most power to my subs, specifically that 300W x 2 zone?
-1996 Camaro 3800, and its purple
K&N, Accel Wires, gutted cat, Flowmaster 80.
Sony Xplod CDX-RA700 HU
Sony Mobile eS XM-7547
2 12" Alpine Type-R's 2 ohms
Kicker DS-60's all around
Old 11-25-2006, 01:21 PM
Alpine_2287's Avatar
Alpine_2287 Alpine_2287 is offline
Re: 4 channel amp??
that amp u got aint no good for those speakers... u need bigger power... that amp is mainly used for door speakers or 6x9's or somthing... those speakers take 500 rms and 1500 max... and ur using like 150-200... go check out hifonics amps... thats what i did...
Old 11-25-2006, 01:22 PM
Re: 4 channel amp??
oh... and a little wise advice... dont even mess with those sony amps ne more dude... i found out the hard way... they aint no good... ("sorry sony")
Old 11-25-2006, 03:55 PM
Re: 4 channel amp??
oh wow, I figured this amp has at least 1200 peak, alright then I guess I'll start shopping around for something bigger. thanks.
Old 11-25-2006, 07:58 PM
PlayStation3 PlayStation3 is offline
Re: 4 channel amp??
if you are looking for more something that is not hifonics try this amp. http://www.edesignaudio.com/edv2/pro...products_id=44 i am getting that amp for my type r's when i get the money
Old 11-25-2006, 09:54 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: 4 channel amp??
there are plenty of amp makers around .... class D amps typically give you a lot more watts per dollar.
Old 11-26-2006, 12:10 AM
alphalanos alphalanos is offline
Re: 4 channel amp??
And pretend that "peak power" doesnt even exist. Always go by RMS. for two type R's you should have at least 500w each. So find a new class D amp that puts out at least 1000w or so.
96 EJ6. Future home of boosted B18C1.
Old 11-26-2006, 01:57 AM
Re: 4 channel amp??
alright thanks a lot guys, im pretty much stuck with this amp for now considering i just dropped a decent amount of money on the subs. and i think ive established that no matter where i hook up the subs on the amp, like on any channel, its still gonna get the same power, right?
Old 11-26-2006, 03:28 AM
Audio Guy
Re: 4 channel amp??
try and bridge the front two channels to power one sub, and the rear 2 channels for the other sub. Hope the amp will handle the load.
Old 11-26-2006, 08:29 AM
Re: 4 channel amp??
how much did you pay for your type r's i got mine for 117 each for 12" 2 ohm ones
Old 11-26-2006, 11:36 AM
Re: 4 channel amp??
is there a place on the forum that can explain to me what bridging is and how to do it? and i payed 149 a piece for them. best buy wants 255 a piece right now, how ridiculous is that.
Old 11-27-2006, 02:35 PM
Audio Guy
Re: 4 channel amp??
bridging is when you connect the left and right channels of an amp together to produce one larger amp channel.
Old 11-27-2006, 02:37 PM
Audio Guy
Re: 4 channel amp??
OMG .... I just had a nightmare. READ the instruction manual, it will tell you how to bridge the amp, if possible. All I could see was someone putting both L&R +'s together and both L&R -'s together from the amp outputs.
Old 11-27-2006, 04:23 PM
Re: 4 channel amp??
i was given the amp from a friend for free, had to get it repaired, which i did, so no manual to read. i took it to a local audio shop and they looked at it for me and set everything up nice, so im pretty sure i got it now. however before i took it there, i noticed that the positive and negative of one channel werent going to the corresponding ones on the speaker, so low and behold i was running off one sub, and the other was just vibrating. remind me never to go to that person again.
Old 11-28-2006, 04:52 PM
Re: 4 channel amp??
If ur using this amp... ur only pushing the alpines 1/3 of there potential. Even if u max the amp out thats all u get... it just depends on how loud u wanna go...
