Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-25-2006, 01:02 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
wheel hop?
how can I get rid of wheel hop?
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 11-25-2006, 01:12 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: wheel hop?
upgrade suspension, upgrade tires, ORRRR sell GS-T and get GSX!
Old 11-25-2006, 01:19 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: wheel hop?
Prothane motor mounts help too.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-25-2006, 01:36 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: wheel hop?
prothane motor mounts took away about 85% of my wheelhop, but 2 of the 4 are a PITA to install.
now - 2000 civic
soon - 2002 is300
Old 11-25-2006, 01:46 AM
Re: wheel hop?
motor mounts would of been my last guess. I learned something new today. thanks. what tires do you recommend? I have some cheap Fuzion ZR1's.
1997 Eclipse GS-T
Old 11-25-2006, 11:02 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: wheel hop?
I have also seen solid front motor mounts. I saw it on some website, it was just a solid piece of metal that connected the motor to the crossmember. It was suppose to help eliminate wheel hop.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-27-2006, 10:01 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: wheel hop?
Motor Mounts FTW... that will take away almost all of the wheel hop... make sure you have had an alignment... and check your suspension (shocks, swaybars, etc..)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-27-2006, 01:51 PM
Re: wheel hop?
well when I bought the car it had a set of goldline lowering springs. which dropped the car 2 full inches. would that be part of the proplem with wheel hop?Im thinknig about putting the stock springs back in because the car it pretty lower stock. I was going to couple the stock springs with a set of some upgraded shocks. I was also thinking about keeping the lowering springs and couple that with upgraded shocks. so as you can tell I dont know what Im going to do yet. any suggestions?
1997 Eclipse GS-T
Old 11-27-2006, 02:38 PM
Thor06's Avatar
Jizzed In My Pants
Re: wheel hop?
I think actually higher spring rates take away from wheel hop. I would just leave them in, get a set of prothane motor mounts, and see how it works for ya.
Old 11-27-2006, 11:04 PM
Re: wheel hop?
is this motor mount complete? is it a good deal?
http://cgi.ebay.com/ebaymotors/Motor...temZ8044613250
1997 Eclipse GS-T
Old 11-27-2006, 11:20 PM
Holset powered 420a
Re: wheel hop?
yea, thats what I got. Good luck with taking the stocks ones out. What kind of struts did they put in with the lowering springs? If they are still stock then they are f***ed by now and thats part of your problem.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-28-2006, 08:20 AM
Mikelb's Avatar
Re: wheel hop?
go for it... that's the kit I got, just for a lot less (I paid like $100 from Summit)... but yeah, that's the complete Prothane kit...
They're a bitch to put in... but there's a write up on here somewhere... or you could just check VFAQ.com
Old 11-28-2006, 12:17 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: wheel hop?
control arm bushings ar ethe #1 fix from wha tI understand but motor mounts will help a great deal also
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 11-28-2006, 01:18 PM
Mikelb's Avatar
Re: wheel hop?
shit, just get all your suspension bushing in urethane... then you're set..
