Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-15-2002, 08:48 PM
civichatch99 civichatch99 is offline
Coil over installation
Hello i just got some r1 raceing coil overs and i was wondering how to install them if anyone could give me a site or something that would help me put these on that would be great. Thanks
Old 09-20-2002, 06:48 PM
Duatone Duatone is offline
first off... do oyu know how to remove your struts? or is that the starting point of your problem? because this is all a relativley easy procedure
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 09-24-2002, 12:23 PM
civ69's Avatar
civ69 civ69 is offline
Send a message via AIM to civ69
straight from the ghetto
Like duatone said its pretty easy. Unless something goes wrong, remove the old struts, you might need a spring compressor to take the strut apart, then install the coilovers on either new shocks or using the stock ones(which i dont recommend). Cut your stock bumpstocks like in half put everything back together, throw the assembly back under the car and tighten everything up. Set your height, get an alignment. And bamm, now you can pick-up chicks, in your squashed out ride.
peace
Old 10-05-2002, 04:18 PM
gotetnies's Avatar
gotetnies gotetnies is offline
Unhappy Yeah Me Too,...
-So I've recently aquired a set of coilovers, and I WAS planning on running them with my stock shocks,... But after doing some research it has come to my attention that that would not be good,...
-So in that case can someone tell me a GOOD shock to replace my stock ones.
-The coilovers were bought New on EBay, and are made by Super High technology (basically a no name brand) :finger:
-I also wanted to know if it would be advantagious to then turn around and buy a camber kit for front and back.
-My main goal is to pimp out my car, While saving money at the same time.
-Lastly I saw an Integtra last night with a set of 5 star Katanna's And man I started to foam at the mouth. The Tegra was dropped with the rims tucked in under the wheel wells, (Which is the exact look I am going for in my Civic)...
Anyways any and all suggestions are welcome... :help:
Cant we all just get along?????
*Currently a member of I JUST DONT GIVE A PHUCK!!! S.D.C.A.
-98' Grn Civic-
-99-00 Si tail light conversion
-clear corners
-CAI
-nuespeed s.s.
-Hyper Blink (Hey I got a good deal)
-Bombz Exhaust
-Coil Overs
-Front Upper & Lower Rear Tie Bars
Old 10-05-2002, 07:00 PM
strodda strodda is offline
Re: Yeah Me Too,...
well i was told by civicsiracer that using stock struts is all bad. since you wanna save money, im not sure what struts you should get, but koni yellows are some of the best, but definetly not the cheapest.
and if you wanna tuck, you probably wont be needing a camber kit. just make sure you get an alignment. you probably wont be able to correct camber much if any since you wont have any play because of the wheel well
Old 10-08-2002, 07:57 PM
gotetnies's Avatar
Smile Strodda
How did you put the (walkaround of your car) on your posting? I have been trying to figure it out ?
-98' Grn Civic-
-clear corners
-CAI
-nuespeed s.s.
-Bombz Exhaust
-Coil Overs
Old 10-09-2002, 07:25 PM
tynebeach tynebeach is offline
Send a message via AIM to tynebeach
yeah strodda the walkaround of your car is sweet! mad props for that
91 Eagle Talon: Exhaust, ported turbo/mani/o2 housing, 15 psi, short route FMIC, etc..
96 Toyota Corolla: DD
weird popping noise ever since i installed DZ coil overs rockabyhater Suspension 0 02-26-2005 12:37 PM
I need instructions of how to install coil overs on my 1994 honda civic!! YoDreDaddy01 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 11-14-2003 11:09 PM
apc coil over install H4Bangin '88 - '91 Civic | CRX | Wagon | Shuttlee 10 09-15-2002 07:04 PM
ok, installing coil over question bobbyd '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-19-2002 10:01 PM
coil over install ericshun22 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 08-02-2002 12:11 PM
