Old 11-24-2006, 10:44 PM
gaboy54 gaboy54 is offline
Whining noise
My 97 Silverado, 5.7L, has a whining noise that seems to be coming from under the truck, just behind the cab. I am guessing that it is the fuel pump?? Is there any wait to tell other than removing the pump? I have read that I have to remove the bed to get to the fuel pump.
Old 11-24-2006, 10:48 PM
jocat54 jocat54 is offline
Re: Whining noise
Some whining was considered normal for some of these fuel pumps? Pulling the bed is the easiest way (my opinion only) to access the pump.
Old 11-25-2006, 09:25 PM
Tall Tall is offline
Re: Whining noise
Yeah; a little whine is normal. But a loud one is an issue. When your truck is running; take the fuel cap off and see if the whine is louder through the filler neck.
I have dropped the tank; and lifted the bed. If you can get a couple guys over; life the bed. 6 bolt; two ground wires; and a wire harness and your done!
Dropping the tank is a beast in it self. =)
Old 01-31-2007, 06:43 AM
mrbee mrbee is offline
Re: Whining noise
I have done it twice and found it easier to lift the bed rather than to remove it.
I did the Ratchet all night and it still ain't Fixed
Old 01-31-2007, 08:28 PM
MyTOY's Avatar
MyTOY MyTOY is offline
Re: Whining noise
when u turn the key to run (not start), u should hear the pump start up.
they are loud. Mine competes with my exhaust. You can have the pressure checked if you're that concerned. Keep your tank 1/4 full for cooling of the
pump. Search this forum & you'll get more info than u want
03 WRX
Old 02-03-2007, 08:10 PM
derekbitt derekbitt is offline
Re: Whining noise
i have replaced a couple of these before and i would say if the truck is running fine (it starts fine, runs/accelerates fine.) leave it alone. let it whine untill the the truck hard starts. if you really must replace it , get it through gmpartsdirect . research prices and youll find out why
good luck
