Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-24-2006, 04:02 PM
octpaul octpaul is offline
no heat
95 sw2..
i'm having an issue with the heating system.
back in the summer, i replaced the waterpump and other related items.
for the past couple of weeks i haven't had any heat.
i just replaced the ect. still no heat.
what else do i need to check ? also checked the small fuses.
not sure about the relays. what do i need to check them?
any ideas?????
does anyone know about a heater valve near the firewall??
Old 11-25-2006, 01:40 PM
Re: no heat
well i just discovered that my lower hose from the radiator to the thermorstat is cold.
so maybe the stat is stuck closed.
will replace it and see what happens.
Old 11-25-2006, 03:39 PM
PlayStation3 PlayStation3 is offline
Re: no heat
your thermsate is stuck open not closed if it was stock closed your car would over heat from the coolent not being able to get to the raditiator
Old 11-26-2006, 06:52 AM
Re: no heat
ok, i'll work on it today.
Old 12-07-2006, 06:30 AM
Re: no heat sw2
still no luck with the heat issue.
i replaced the thremostat and ect sensor.
where do i go from here..maybe the radiator????
Old 12-12-2006, 01:42 PM
wrparks wrparks is offline
Re: no heat
What about a stopped up heater coil so the heated coolant never enters? Just a guess, but I'm sure there is a valve of some sort there. Good luck.
Old 12-12-2006, 01:59 PM
Re: no heat
is the heater coil located under the glove box?
does anyone else have any exp. with the heater coil?
thanks for your reply wrparks.
Old 12-13-2006, 08:16 AM
Re: no heat
I don't know much about the heater coils in Saturns, only in older trucks where I have had some work done. But yes, in most of them the coil is located around or behind the glove box. Saturns may have a completely different setup than these though. Just out of curiosity, is the car getting up to normal operating temperature?
Old 12-14-2006, 03:00 PM
Re: no heat
yes, it gets to normal operating temp.
about half way on the temp gauge.
the heat becomes luke warm for a few minutes, then it gets cool.
Old 12-14-2006, 04:53 PM
ksion15's Avatar
ksion15 ksion15 is offline
Re: no heat
there is a door inside of the hvac module that opens and closes to allow air to pass through the heater core. it moves to control the selected temp. a cable runs to it from the temp. knob on the ip. listen to hear if the door is moving. if not, it could be stuck, the cable could be loose, or broken, or the back of the switch may be broken. from what you've said already, it sounds like coolant is flowing through the heater core. so the heats there, there's just no air moving through it to get to you.
K.S.
Service Technician
Saturn of XXXXXX
ASE Certified
GM/Saturn Certified
Old 12-15-2006, 09:26 AM
samprix samprix is offline
Re: no heat
ksion15 is prpbably right.
The slide temperature selector is prone to being operated too harshly as compared with a knob. This could possibly cause breakage to the cable or the plastic connectors.
Old 12-15-2006, 11:39 AM
Re: no heat
thanks for your replies........ i'll check that today....i hope..
at least it's not freezing yet in N.J.
i may have to check it out on the weekend instead.
