Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 11-24-2006, 04:23 PM
Cat Fuzz Cat Fuzz is offline
81 El Camino V-6 carb problems
This thing is dumping gas. Can anyone give me a run-down of the extend of computer control of this? Normally I'd pull the carb and check it out, but could there be some other problem as to why its running so rich? Some sensor or other controlling part? It's bone stock, 231 V-6 with 2 bbl carb.
Old 11-27-2006, 09:45 AM
Blue Bowtie's Avatar
Registered Offender
Re: 81 El Camino V-6 carb problems
If it's the common E2SE carburetor, about the only thing the ECM can do is operate the mixture control solenoid to slightly adjust the idle mixture. If it's dumping gas, there's a chance that the inlet needle/seat are not sealingm the float is hanging up or contaminated and no longer floating, or the main metering well plugs are leaking.
Old 12-07-2006, 09:36 PM
Thanks for the help. Did a carb kit and new float as well as a thorough cleaning and the car runs really good now. But it still has a problem with a random stall on take off. It's been a few days and I thought all was good but today it cut out and died. Is there anything else that can be going on here besides the carb?
Old 12-08-2006, 09:39 AM
Registered Offender
If there is an EGR system, make sure the vacuum routing is correct. The EGR TVS should get its vacuum source from a timed port on the carb. If the source is a constant manifold vacuum, the EGR may be opening when you don't want it. Likewise, you'll want to verify the vacuum connection to the distributor advance.
Old 12-08-2006, 11:48 AM
Should there be vacuum to the EGR valve at idle? I wouldn't think so but there is on this car. When I pull the vacuum line, at idle, it runs a little bit smoother. Would it harm anything if I disabled the EGR valve for awhile to see if the stalling comes back?
Old 12-15-2006, 05:18 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Old 12-17-2006, 03:44 PM
twistedtech twistedtech is offline
Originally Posted by hotrod_chevyz
LOL, i love it,it's like going through the buy and sell,one ad above the other
Wanted: small block chev,running
For Sale: small block chev,running.
Sometimes the answers are right in front of you.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 04-08-2007, 11:42 PM
Well, it's been a while but I pin-pointed a pattern to the stalling problem. It only croaks when going downhill for some reason. I can only think that the carb would still be at fault here, but I can't think why.
Anyone else have a clue for me?
Old 04-10-2007, 10:08 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
This is hard to diagnose without having the car in front me. If you can pull the top of the carb off easily enough, re-check the float level and take sure it can swing full travel.
Bob
