Old 09-15-2002, 06:55 PM
djmr2's Avatar
djmr2 djmr2 is offline
Color for Panel Lines...
Hey guys
what color do u think looks good for the panel lines on a white car?
Should i use a flat black but really washed out or use a lighter color?
this one looks great...
Old 09-15-2002, 06:59 PM
daggerlee's Avatar
Definitely should use a grey, not sure if a light or dark grey would would work better..
BTW, that S2000 looks kickass, great shine. How's the airbursh working out?
Dan
Old 09-15-2002, 07:34 PM
ZoomZoomMX-5's Avatar
Wash colors
That's a gorgeous S2000. Did you build it?
I use a light to medium gray for the panel lines on a white model. This is much more realistic than black.
I guess as a future endeavor I can post a color chart of recommended panel line wash colors for a variety of body colors. Since I've switched from black my models look much more realistic.
Old 09-15-2002, 08:21 PM
primera man's Avatar
"P-Man"
Re: Wash colors
Please do that
View All My Models Here.
Old 09-15-2002, 08:30 PM
djmr2's Avatar
Yo!
i didn't build that..
i found it on a website... IMO the panel lines are just PERFECT!!
thats wut i want to do...
Daggerlee, i finally got my replacement nozzle from dixieart after they screwed around for a few weeks and never shipped it out... but it was working great before... hope to paint my z06 sometime soon... painting it white, so gotta know wut to do with the panel lines!
Old 09-15-2002, 08:31 PM
djmr2's Avatar
just another question...
is it critical to use enamels for panel lines? i mean with the extra drying time needed, might work a little better?
right now , all i got in my inventory are acrylics and mr. color
Old 09-15-2002, 09:04 PM
Panel line painting
A panel line wash needs to be in a different paint formula. If the car is painted w/enamels or lacquers, use acrylics. If the car's painted w/acrylic, use an enamel-based wash. This will prevent the thinner (the wash is mostly thinner) from attacking the paint below it. It also facilitates the removal of excess paint. If you paint your panels w/an acrylic wash, you can remove the excess w/a cotton swab wet with window cleaner, like Windex. Rubbing alcohol works too. Basically anything with alcohol or ammonia will remove acrylic paint (like Tamiya or Gunze).
Hope this helps
There are instructions for painting acrylic panel lines and other things on the Tamiya website.
Tamiya How-To Tips
Old 09-16-2002, 12:02 AM
djmr2's Avatar
hehe
well i guess it would help other people that don't know that stuff..
but what i'm wondering if using the acrylic wash is good or not... cuz i'm worried that the acrylic wash will dry out too fast to get a good even flow down the panel line... but i'm gonna get it a try.. it doesn't hurt anyways... i strictly use Lacquer (Tamiya, Mr. Color, Automotive) for the bodies.
btw, i heard enamels don't like anything to be put over them. Lets say i use the enamels for the panel lines, how would my clear coat affect it.. i'm using Future which is acrylic based.
Old 09-16-2002, 06:36 AM
It doesn't dry THAT fast! Try it, you'll like it
Two observations. First, it's best to add the panel line wash last. You don't want the lines glossy, use flat colors for the wash. Glossy lines look funny if the light hits them just right.
Second, if you're using lacquers like Tamiya for the bodies I'd use their clear rather than Future. Future can work wonders, but Tamiya paints buff out so nicely that unless it's a metallic/pearl they don't need clear. If you're set/comfortable w/Future and are getting good results, by all means test an enamel wash with it, because it will look best done last. Usually my final stage of a buildup is the panel lines, followed by a final polishing job to remove the residue and fingerprints. Then bask in the warm glow of a completed project
Old 09-16-2002, 09:41 AM
djmr2's Avatar
Yeh
well the thing is if i do the acrylic wash last, then i can't use future...
yeh i am getting good results polishing future and it's so cheap...
i'll see how the enamel works out on the future..
Gundman Markers for Panel Lines BVC500 Car Modeling 3 08-24-2006 08:46 AM
Gundam Markers for Panel lines hueb_s Car Modeling 3 05-25-2004 07:56 AM
panel lines colors Mr=P Car Modeling 8 02-11-2004 02:29 PM
Does anyone use this method for panel lines? Jedi801 Car Modeling 6 02-04-2003 06:04 PM
Pen for panel lines? efi-street Car Modeling 7 02-24-2002 07:50 PM
