Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-24-2006, 02:11 PM   #1
mudvaynesadvokit
No power dies at 4000 rpm
Well this is my first post but I need to find out what is going on with my mustang. If I'm easy on the throttle it will go up to about 4000 rpms while I'm driving but not much more. If I stomp on it then it just completely loses all power. I've heard clogged cats or clogged fuel filter possibly. It does flash the check engine light every now and then too. Any input would be greatly appceciated.
mudvaynesadvokit is offline   Reply With Quote
Old 11-24-2006, 05:37 PM   #2
eggfarmer
Re: No power dies at 4000 rpm
need more info------- eng. size/year?
eggfarmer is offline   Reply With Quote
Old 11-25-2006, 01:51 AM   #3
mudvaynesadvokit
1995 5.0 standard
Old 11-25-2006, 10:01 AM   #4
eggfarmer
I have had some experiance with this trouble and it was the TPS switch.
Old 11-26-2006, 05:04 PM   #5
mudvaynesadvokit
Well here's an update. I replaced the fuel filter and the acceleration problem got better but it clogged right back up in 10 minutes so i'm going to drop the tank and replace the fuel pump, clean the tank out, and put a new filter in. I also replaced the TPS and that didnt work. I'm leaning heavily towards clogged cats. The car has 4 cats and has 90000 miles on it.
Old 11-26-2006, 08:09 PM   #6
reekor
Why not see why the check engine light is coming on first, instead of just throwing parts at it. While you have a scan tool on the car see what the 02 sensors are doing and run a KOER test.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
reekor is offline   Reply With Quote
Old 12-03-2006, 11:02 PM   #7
mudvaynesadvokit
Problem solved. All issues due to bad fuel pump. I put in a 255lph pump and it runs like a champ. Thanks for all the input though.
Old 12-03-2006, 11:09 PM   #8
eggfarmer
thanks for letting me know. sorry I was wrong.
